1958 D14 - 3 pt Hitch, No Arms
Kamikaze_Emu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kamikaze_Emu Quote  Post ReplyReply Direct Link To This Post Topic: 1958 D14 - 3 pt Hitch, No Arms
    Posted: 15 May 2022 at 3:00pm
I am super new to tractors and I am looking to purchase something to help me with grading, back filling, etc during a house build, and then snow clearing and other misc. tasks on a few acres once the house is complete.
I found a D14 in my area, however in the ad the seller notes that the tractor has a 3 pt hitch, but without arms.
This is a photo of the rear of the tractor.
What parts would I need to get so I could use a grader blade or a snowblower?  Is it even possible?  Without the arms in place would the hydraulics for lift be present on the hitch/tractor as is or would I need to run additional hydraulics?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 3:36pm
A D14 never had a 3pt from the factory. You have the snap couple lift latches. You can get an adapter that connects to the snap coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 4:14pm
I have 3 of the 'Snap-Coupler to 3PT adapters here near Hamilton,On. where abouts are you ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kamikaze_Emu Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 4:33pm
I am near Ottawa.
If I purchased the tractor I would be interested in the conversion kit.
What are you selling them for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 4:40pm
wife would toss it in if you bought a D-14 off me.....
...so gotta think up a price...yer 5.5 hrs away...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kamikaze_Emu Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 4:46pm
Amazing, thanks.
With the proper terminology I was able to do some searching and the whole situation is a lot more clear now.
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kamikaze_Emu Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 5:36pm
Jay
The float fees on the tractor would probably make me cry.  It is too bad you aren't closer, I wouldn't hesitate to come take a look at one of yours.
I was looking at some 3 point conversions and it looks like the draw bar on the tractor isn't the standard one and there are some extra bits of metal below the PTO near the bar.  I'm wondering if that might cause me issues with the conversion kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 6:23pm
Yes, that draw bar is homemade... I have 2 or 3 real ones collecting rust, er ,dust, here.
When I removed the loader from 'Troy', I made a 'carry-all' which has a 2" receiver on it. I put a sleeve in ( 2" ball for trailer tugging, empty to use as a drawbar ). carry-all has removable (ugh..) 5000# forklift forks on it.
 Will take pictures of the 'adapter' tomorrow,hopefully after I 'acquire' several loads of 'ponypoop'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 6:37pm
The seller is ignorant. It is NOT or ever was a 3-point hitch. There is no top link connection !!  It doesn't even have a regulation snap-coupler drawbar.  Do the lift arms even go up and down ??
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 6:42pm
Looks like some crude torch work on the home-built drawbar. I would check the tractor over very carefully before buying it.
Make sure it doesn't jump out of either second or third gear. Transmission repairs are very expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 7:00pm
there are a couple different "generic" designs for 3 point adaptors for the ALLIS tractors.
The first is a VEE shaped lower arms with the bail built into the end that replaces your present drawbar... and two arms that connect up to your lift arms... you still need a TOP LINK for the 3 point.
Second type is a bracket that bolts to the tractor  / drawbar and then has two individual lower links that pin to it... and again two arms that connect to your lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 7:09pm
The second (lower) picture requires the OEM drawbar bail, which this tractor doesn't have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kamikaze_Emu Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 7:20pm
Thanks for that.  I was looking at kits and the second style I could find in my area, but thanks to your info I realize it isn't going to work.  If I went with the VEE shaped kit would that include everything I need to get me to the point where I could use standard 3 point hitch accessories?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kamikaze_Emu Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 7:21pm
Sounds good, thanks.
Is there a handy used buyers guide kicking around anywhere for me to reference?
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 8:34pm
You can build a 3pt hit kit, it's not hard. I built the one on my D17 so if I can do it anybody can do it!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 8:35pm
This is the place for your used buyer's guide.  There is a lot of knowledge here.  I personally have 3 D14s and absolutely love them.  Unfortunately, AC was late joining the 3 point hitch game.  The D15 (which succeeded the D14) had a 3 point as an option, but was pretty flimsy.  For a good rugged 3 point hitch set up, you would want a Series 4 D17 - a considerably larger and more expensive tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 8:58pm
Jason.. you want a 3 POINT HITCH.. look at the picture and you can see the lower two arms that are lifted by your UPPER HYDRAULIC arms on the tractor... You are STILL MISSING the upper link or the 3RD ARM for the 3 POINT...  that is normally an adjustable link that is attached to a BRACKET above the pto housing near the back of the seat.. Couple different ways to "make that".
Edited by steve(ill) - 15 May 2022 at 9:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2022 at 9:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2022 at 7:18am
I have a CNC version of the '3 holed top link bracket' here,well 3 really....
Also a snap coupler read blade, wife says I don't need....a 3 furrow plow, wife says I don't need, a 5' rototiller, wife says I don't need, a ?-version subsoiler, the wife says I don't need, a 9 tooth cultivator, wife says i don't need and of course 3 D-14s, yes, the wife says I don't need....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2022 at 9:09am
Jason... i think its time to start calling Jay... Daddy... and maybe he will adopt you !! Wink
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2022 at 9:31am
I have a Cross Manufactured 3 point on my 52 CA, Cross is out of Mindenmine Mo. I do have motor side weights on it, I hook a 5 foot bush hog,box blade ,scraper blade and a 50 gallon boom sprayer, not once has the front end left the ground, it does get noticably easier to steer until the sprayer has used about 1/3 of the contents,but even full the wheels have never left the ground.
