Unknown 3/8" set bolt
Monte Mahan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monte Mahan Quote  Post ReplyReply Direct Link To This Post Topic: Unknown 3/8" set bolt
    Posted: 23 Jan 2022 at 3:24pm
I'm in the process putting together a C allis I purchased in parts and have a 3/8" set bolt I havn't found a spot for it yet.  I'm pretty sure it goes on the outside of the motor cause it has a little orange paint on it.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2022 at 4:59pm
Might go on the front of the governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2022 at 5:04pm
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2022 at 5:08pm
goes in pulley on front of crankshaft...  its a tight fit ... but also looks like adjustment screw on steering box cover ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Monte Mahan Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2022 at 6:42pm
Thanks juniorp53.  I owe you a beer.  There was no set screw in the crankshaft pulley and I put an allen setscrew in there.  I had looked at The steering set screw and it was in there.    Thank's again.
