Ross Steering Box
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Topic: Ross Steering Box
    Posted: 19 Sep 2010 at 3:36pm
The Ross Steering Box should I use gear oil or axle grease in it?
An interesting observation, I had the two steering boxes apart, one off my 52 B and the other one somewhere in the 40's , the seal in the 52 is a neoprene material and the one in the 40's was cork.  Other than that no difference.  The pin on the sector gear on both of them were worn.  However, one of them had been repaired by someone who mearly welded the metal that was worn off but it had worn again.  So I decided to try it myself, I had nothing to loose and everything to gain.  I  welded and filed it until I got it as good as new, well almost new.  I'm sure it cannot last as long as a new sector but for the use that it's going to get by us it will last a long time.  Besides I have the option of making use of my welder again.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 6:19pm
I use gun grease rather that wheel bearing grease. My thought it would tend to seep into the groove better as it softer and when it gets warmer it will kinda run.
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 7:12pm
I've rebuilt a couple that had been filled with grease, the shaft's were badly damaged from lack of lube to the bushings. I use the thickest gear oil that I can find. If you use grease, cornhead grease would be your best bet.
CA Tractor
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2010 at 8:37pm
  I drill & tap the cross shaft housing between the bushings and put grease fitting in  when you grease the front end put a shot or too in cross shaft fitting
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 7:48pm
Fred - I believe Tracy Martin makes replacement pegs for the steering box.  AL
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2010 at 7:51pm
Al's correct - I bought a kit from Tracy for my CA.
WC, CA, D14, WD45
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 9:12am
The gearbox lube should be 80 or 145 wt as it also lubricates the upper and lower bearings in the box. I have had to rebuild the bearings  on a few of these boxes where someone decided to lube them with grease instead of oil. The top (and sometimes the bottom) bearings get all pitted up and fall out due to lack of lube and/or water. Found that the balls from a #6205 sealed bearing are the right size; have not found a source for the races and have reused them by putting the best race on top and the worst one one the bottom. The steering shaft side seal is still available from AGCO; however have made my own gaskets for the side plate.
Pwombles81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pwombles81 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 8:42pm
I know this thread is older, but does anyone know if Tracy Martin still makes the pegs for the steering rod for an allis CA? I am in need of a set. Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 8:49pm
Welcome to forum. Tracy is on forum. You should start a new topic in farm equipment section asking same questions. He should see it and respond. Goodluck
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 1:56am
Hi all when I rebuild my Ross steering box I pressed out the pin out and moved it 90 degrees and put it back in so was working on a new face of the pin it works perfectly
Tractors Allis EB,two C,diesel G
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 1:38pm
We rebuilt  the steering box on a B and had success at Sandy Lake getting new bearings and I think races too. Awesome people to deal with.
