pie weights
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Topic: pie weights
    Posted: 16 Sep 2021 at 8:08pm
what are your thoughts on pie weights just bought 8 of them for our D14 I will try to post a pic tomorrow. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 8:30pm
They work - just keep the bolts tight
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 8:38pm
Easier to add weight a 1/4 at a time verses 1 whole weight if that’s what your asking. Our D15 has them and I have a complete set for my 190XT if I would use my 4 bottom plow or pull the 20 ft disc. The disc requires more weight than just the loaded tires. Otherwise I leave them off for hay season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 8:59pm
Thanks this is the first time i have used steel weights. always tire ballast . have rim gaurd in my new tractor adds about 1000 lb. Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 9:14pm
My WD has fluid and a wheel weight on each side. The wheel weight requires a second person to install the nuts as I hold it in place. Quite hard on your back. Pie weights are much easier.
