pie weights
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=183283
Printed Date: 29 Apr 2024 at 9:39am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: pie weights
Posted By: Randy WI
Subject: pie weights
Date Posted: 16 Sep 2021 at 8:08pm
what are your thoughts on pie weights just bought 8 of them for our D14 I will try to post a pic tomorrow. Randy
Posted By: DougG
Date Posted: 16 Sep 2021 at 8:30pm
They work - just keep the bolts tight
Posted By: AC720Man
Date Posted: 16 Sep 2021 at 8:38pm
Easier to add weight a 1/4 at a time verses 1 whole weight if that’s what your asking. Our D15 has them and I have a complete set for my 190XT if I would use my 4 bottom plow or pull the 20 ft disc. The disc requires more weight than just the loaded tires. Otherwise I leave them off for hay season.
------------- 1968 B-208, 1976 720 (2 of them)Danco brush hog, single bottom plow,52" snow thrower, belly mower,rear tine tiller, rear blade, front blade, 57"sickle bar,1983 917 hydro, 1968 7hp sno-bee, 1968 190XTD
Posted By: Randy WI
Date Posted: 16 Sep 2021 at 8:59pm
Thanks this is the first time i have used steel weights. always tire ballast . have rim gaurd in my new tractor adds about 1000 lb. Randy
Posted By: AC720Man
Date Posted: 16 Sep 2021 at 9:14pm
My WD has fluid and a wheel weight on each side. The wheel weight requires a second person to install the nuts as I hold it in place. Quite hard on your back. Pie weights are much easier.
