D17 lift power in pounds? |
Hunt4Allis
Orange Level Joined: 13 Mar 2018 Location: Ohio Points: 1160 |
Posted: 18 Jun 2021 at 9:22am |
Hi fellas,
Anyone know what a series1 rear arms should be able to lift? Also what is the hydraulic oil level supposed to be on dipstick- near gear shifter? Thanks Matt Edited by Hunt4Allis - 18 Jun 2021 at 9:23am |
Hunt4Allis
Pimples here the question I'm asking is in reference to whether or not a d-17 can lift a 4x whether or not a d-17 can lift a 4x5 round bale approximately 800 lb that is situated right against the lift arms so as close to the tractor as it can be of course with a bale spear and two points below to assist
Hunt4Allis
The question I'm asking is in reference to whether or not a d-17 can lift a 4x5 round bale approximately 800 lb that is situated right against the lift arms so as close to the tractor as it can be, of course with a bale spear and two points below to assist?
No weight on the front, I'm sure it's capable but I'm wondering what the maximum lift capacity is? Edited by Hunt4Allis - 18 Jun 2021 at 6:34pm |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77748 |
I would think a D17 could lift 1000 pounds if the load is kept close to the hitch point.
Orange Level Access Joined: 12 Sep 2009 Points: 19519 |
The lifting potential is directly related to how healthy your pump is !! A very healthy pump should unload at 3700 psi. An old dirty and worn pump might be as low as 2500 psi, about 30% less. The internal lift arm cylinder is smaller in diameter than a series 3 tractor, again affecting lifting power. A diesel chassis has more front end weight than a gasser. A wide front has more weight on the nose than a NFront end.
Edited by DrAllis - 19 Jun 2021 at 6:04am |
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Just adding to what has been said. With a working pump there should be no issue. Your tractor will most likely be a little light on the front and would benefit with a few weights. Our first round bale moving tractor was a series 4 with wide front and a rear mover. Just want to point out how dangerous those rear movers are in the dark. My father backed over a black calf that was in the feeder when setting a bale in, not long after we heard of a boy that was killed the same way. Father was one of our customers, it was a tough time. We switched to a front end loader around 1980 after those accidents.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3286 |
so how much does a two or three bottom roll over plow weight? handles them just fine hanging out there
Hunt4Allis
Right ok.
I know there's alot of variables but I just wanted to know if it was feasible... WF on mine, rig is almost touching pto shaft. We will see. Thanks guys |
BillinAlberta
Silver Level Joined: 12 Sep 2009 Location: Saskatchewan Points: 330 |
Yes it can .I can pick up 5x5 bales easily at 1200 lbs but it has a front end loader out front for weight.Usually carry 1 in front and 1 behind.
Hunt4Allis
It worked perfectly!
Got them all moved in short time up on dry hill in pasture. It couldn't have worked any better, not pretty but from a used pile of parts and some welding/ fabrication it all worked out nicely. Thanks fellas Edited by Hunt4Allis - 19 Jun 2021 at 3:27pm |
Thats a very HANDY looking rear lift !!
Hunt4Allis
I can use it as pictured or remove spear and use as a pallet lift, remove forks and add a ball in middle to go get firewood with my trailer in our back woods, also built a pig pole with lifting eye that's adjustable along the length of pole that I welded up from square stock and it attaches to top link
DaveSB
Silver Level Joined: 04 Aug 2012 Location: mocksville, nc Points: 235 |
Great job on the bale mover,I like how you made it. I knew the D17 would work, my neighbor moves them with a D10, I know much smaller tractor, but it works fine for him.
Thanks for the pictures, enjoyed them. |
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Hunt4Allis
I feel like the pictures were owed to everybody who gave me insight on how to build this with ideas, I've been thinking and gathering parts for a long while to do this one!
HudCo
thosepallet forksare allways handy
