Concrete poles |
Post Reply | Page <12 |
Donaker
Bronze Level Joined: 20 Sep 2021 Location: Alaska Points: 1 |
Yep, the price for lumber today after hurricanes is too high. Using concrete poles instead of wood 6x6ms is more complex than lumber poles. I don't know much about building a shed with concrete poles. You might need to use the concrete contractors' company at least for planning your building. When I met this kind of problem building a new shed for my car, I went to professionals in my area fremontconcretepros.com, this company solved my problem, after the hurricane I needed only to do a small repair on the roof.
Edited by Donaker - 22 Sep 2021 at 2:37pm |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29521 |
OK just picked this one. First off 6x6 concrete will flex with side loading, thus that factor of 10 rule, as they flex they stress fracture and allow moisture in, degrade the resilience of the concrete and allows moisture to the steel re-rod, it corrodes and stresses the concrete further by expansion of said rust. Failure in a few years at best. That is the reason Concrete Columns in any exposed construction tend to be LARGE Diameter.
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6645 |
Why not get used telephone poles? Heck, buy new ones?
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3286 |
hear if you buy the sand rock and portland cement it is stil over 100$ dollars a yard and that isnot the cost of hauling the product that waas what it cost us five years ago we hand mixed 15 yards ready mix hear is 185 delivered we was going to have a pad poured behind our shop this year steel is still the cheapest for a equipment shed
IF determined to go Wood, expand on some considerations. Wood post generally do not rot off Below Grade, they rot At grade where the Biologic critters live, treating only preserves the post against insects, not fungus or bacteria which essentially is what creates the rot. Wrapping the Wood post with tar glued plastic and are post wraps available to do same thing, well above grade line will reduce the problem just not eliminate it. Are several new materials to fill the holes instead of conventional stone millings or screenings(IE Concrete Foam), can even set Piers some 30-48" into soil with a Post anchor on top set to Height where the post themselves will not be wetted or available to munching microbes.
As Wood product pricing continues to lower, wood again can compete against steel supports done similarly to last response.
Edited by DMiller - 21 Sep 2021 at 4:37am |
MichaelSavan
Bronze Level Joined: 26 Jul 2022 Location: New Jersey Points: 2 |
I don't think it's a great idea if you've never built or studied concrete foundations for buildings. It's an extremely precise job that requires a lot of planning and calculation. The surface has to be very level, which is quite difficult to arrange. It is best if you use some tools for this, which you may not have. Also, the materials, including tools, may not be cheaper than wood. So I honestly don't see the point in such an endeavor. However, if you want a concrete floor, I suggest hiring professionals from jmballaratconcreters.com.au to get it done perfectly. Or try to do it another way
Edited by MichaelSavan - 17 Nov 2022 at 5:19am |
Another option, Scrap or Seconds Pipe Sales. We have one in Owensville MO. 6x6 or 4x6 Square Steel pipe or even tube(Thinner wall) set a mounting bolt square in a concrete pier, drill pads and weld to one end of pipe, set pipes, can add plates with drilled holes for Girts and still build pole barn style., "L" Saddle at the top for truss nailer plate. Set them 6 or 8'OC at the ends diagonal brace reverse from each end and will be solid, secure, square.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5637 |
It is pretty hard to do it alone." Spammer necroposting.
shameless dude
just checked with local concrete company for price of concrete for our new home....quoted $150. a yard
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21468 |
and it weighs 150# per cubic foot.... so costs 4 cents per pound hay, I woke up to WHITE this morning !!!! grrr.....
