1949 Allis Chalmers WD project |
Post Reply | Page <123 |
Author | ||
55allis
Orange Level Joined: 30 Jun 2020 Location: Southwest IA Points: 545 |
Thanks ac45man I figure it out with your pictures.
Sponsored Links | ||
55allis
I got all the decals out of the bag and well there is some different ones I never seen before.
I have got them all numbered to help identify them. The black squared ones I think I know where they go but the rest would be nice to have a reminder. Down here I have the original picture without the edit. |
55allis
Well yesterday I started it for the first time in 6 months and after cleaning some connection it started like a good Allis should!! I also took the Final drive pans into my local welding shop and had him put drain plugs on the bottom of the pan.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8167 |
Wonderful news! The decal placement is always a issue. I have used pictures and other original tractors for location. Take your time get them as close as you can. They look better when correct too.
Regards, Chris
55allis
Well here’s the results!!
And I love it!! Pulled it out the first time with all new paint. |
ac hunter
Orange Level Joined: 05 Jan 2011 Location: OHIO Points: 948 |
Looks great. A nice reward for all your work. Hope you enjoy driving / showing / whatever with it.
Sugarmaker
55,
It looks right at home! Your going to like having it around! Tires make it look ready for some serious work too! Decals look good! Thanks for keeping us up to date! Regards, Chris
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3448 |
Good work, looks sharp.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4637 |
Wow, nice job. Really like that serious rubber on the rear. What size tire is that?
55allis
16.9X28 Firestones |
55allis
Here’s a picture of it before and after.
55allis
Well I found a wide front for it!!
55allis
Earlier I was plowing and the brake rod broke off inside the axle ( it rusted out) so I was wondering if anyone else had that problem?
Orange Level Access Joined: 12 Sep 2009 Points: 19509 |
Well, you know when things are 70 years old, they might rust out in places.
jvin248
Silver Level Joined: 17 Jan 2022 Location: Detroit Points: 268 |
Probably involves taking the brakes apart (guessing) ... which if that is the case you should watch several youtube videos. You will see where to spray as much 'PB Blaster' as possible to get those lower brake pins loose. I've already started spraying mine for the spring/summer WD project I got in December. Post some pictures and fast help will follow.
corbinstein
Orange Level Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
took lots of heat, PB Blaster and a slide hammer to get mine out.
55allis
Hmmm...
Sounds like it’s going to be fun job!! Does the axle have to come off though? |
Dirt Farmer
Silver Level Access Joined: 15 Sep 2020 Location: Illinois Points: 279 |
No the axle doesnt have to come off to work on the brake shoes, take the top tin covers off, one to the left and a matching one under the seat frame, everything comes out and goes back in through there. There is an inspection hole under the axle to look in and line everything back up as you reassemble, as my Dad would say, have to be patient and hold your mouth just right. Good luck
jvin248
. That inspection hole under the brakes seems to be sized perfectly for mice to build nests, I think mine has one too. Most of the youtube videos seem to be knocking fluff out of there too. The mice accelerate any corrosion going on. Peppermint oil extract (if you know anyone making/using aromatherapy may let you borrow a few drops), put in there should keep them out for quite a while. I think the brake rod attaches at the top of the shoes to a small cross-bar. If that's the case you might only need to replace the rod and maybe that top cross-bar. Assuming the pads are still good. And you avoid the lower pin removal project. .
corbinstein
some have had to take a blue wrench thru the inspection hole and cut the pin in two.
I've had to heat the casting around the ends of the pin and put copious amounts of pb blaster in. I welded a slide puller to the pin (under the tractor) and pulled it that way. Lots of cussing.
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3651 |
I'm looking forward (not) to doing the brakes on my WD in the spring. The left side pin moves easily with the pin removal tool from DJ's. The right one is in there solid and won't move. I'm soaking it with applications of Kroil over the winter. I don't want to get into it now as it's my main snow plow tractor and brakes aren't used much when plowing snow drifts.
55allis
Now you’re scaring me lol!!
At least it’s only one side. I put a wide front on it the other day and here’s a picture of it... |
IBWD MIke
Nice!
55allis
So it’s been running great for so long that I started thinking of it as a dependable tractor, well that was stupid of me…
Today I was moving it from our house to our main shop (which is a 2 mile drive on a gravel road) and got there, I shut it of out side of the shop door to open the door (it’s a rolling door) and move a few things and I jump back on the wd to start it and well I was cranking it over the carb bursted in to fiery flams. We got the fire put out before it ruin the rest of the tractor but I think from looking at the out side of that carb is toast!! I think all the damage done was the carb and the intake hose and a little black around the carb area. So dumb dumb me first thought of mind is kill the fuel only problem is being that close to a gas fire is dumb but heck it keep it from getting any more fuel. I don’t have any pictures yet but will try to. |
55allis
I never mentioned that I just put a new needle and seat in the carb because it was sticky where it would sometimes stick open and make a mess and stick shut and kill the tractor…
Other than that I can’t figure it out why it did that… |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
WHAT???? How does a fire break out at the carb? Not possible unless somethings missing. What ignited it?
55allis
It was the carb. I did check the wiring but was all good from what I could see… |
DSeries4
It does not answer Steve's question. The carb cannot ignite gas. With an incorrectly installed needle and seat, the carb will gush gas like crazy, but something had to make it catch fire. I would be investigating that first.
BigGuy1000
Bronze Level Joined: 06 Dec 2013 Location: NWIL Points: 107 |
BUT I had an AC170gas (similar engine) just 3 months ago where the leaking exhaust manifold or gaskets did ignite gas in or around the carb and manifold!!! The intake hose swelled up REAL BIG and came loose, blew off the dirt cup of the air cleaner, smashed the top of one carb float so that float would not stop gas running into carb, gas then ran out of the carb air intake, engine had stopped, gas had to be shut off, all due to ignition problems!!!
Had to tow the tractor away.... |
55allis
Hmm
What big guy 1000 said sounds like a clue… That manifold is pretty rusty, wonder if it blew a peep hole between the two parts, I’m not sure if that’s possible but that sounds like a pretty good clue. That black was not there before the fire…. Edited by 55allis - 24 Oct 2022 at 11:42pm |
