AC 60,70 and 80 plows?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 60,70 and 80 plows?
    Posted: 14 Apr 2020 at 9:29pm
What was the narrowest plow in each series for 2 bottom, snap coupler and 3 point hitch? Thanks Tracy
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 9:41pm
Without looking at my plow bottoms parts book, I'd guess 10 inches was the narrowest plow bottom. 60 and 70 plow frames were made with fixed plow bottom widths. The 80 has adjustable frame widths. Each frame design has a different way of connecting the plow bottom shank to the the frame to handle the effects of hitting anchored stones.
There is an article on plows over on the Knowledge forum that has links to downloadable plow frame parts book and plow bottoms book. Both will show the details of the widths of each family of plow frames.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 10:02pm
Gerald, that was a big help.It tells each size of each series. I have a couple of questions still. What trip bottom has the little bar on outside of trip mechanism? Could each bottom of same number, as a 364,374,375 be had solid and slatted moldboard?Thanks Tracy
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 9:25am
I've seen the 10" bottoms listed in different plow books, never seen one in person. Not sure I've even seen a 12". Fourteens all over the place with a few sixteens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 9:54am
70 and 80 series are the same frame and adjustable for width, but only two inches, like 14 to 16 inch etc.. 70 series is shear bolt trip and 80 series is spring/toggle trip. Same frame between them both.  50 and 60 series were non-adjustable.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 5:03pm
Here is a video for viewing pleasure on the various AC plows:
[TUBE]4U9PPauc4EA[/TUBE]
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 6:55pm
I have several of the spring trip plows. The trip mechanism is different. One has bar that is horizontal and goes down the side, the other has a clevis looking strap on rear. Tracy
