Replacing auger drive belt on model 72 combine |
Post Reply |
N186364
Bronze Level Joined: 05 Jan 2020 Location: Ontario, Canada Points: 25 |
Posted: 01 Apr 2020 at 7:22pm |
The unloading auger drive belt on my model 72 combine needs to be replaced ( the parts book calls it : belt, unloading conveyor ). Does anyone have a good " how to " on this especially regarding how to get the new belt around the PTO drive shaft? Also does anyone know the size of the belt?
wlambs
Bronze Level Joined: 18 Jun 2018 Location: ga Points: 67 |
HAVE TO UNBOLT THE PTO FRONT SLIDE BELT ON THEN THE BACK. ALLCROP HARVESTER HAS THEM TOM YAZZ
TomYaz
Orange Level Joined: 14 Sep 2009 Location: PA Points: 10319 |
What he said. Specifically part # 1 below:
Ryan Renko
Orange Level Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2315 |
I actually had to replace a leaky front oil seal on my gearbox and while I had the front drive shaft removed it was a perfect time to replace the auger belt. Ryan
N186364
That's great. Thank you all. Tom, a picture says a thousand words. I'll take a run at this in a day or so. Do I have to worry about a torque value when I re-assemble the PTO shaft?
den/southern illinoi
Orange Level Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 1932 |
I have had instances like this where I put two belts on at the same This is mostly when the belts go bad quickly. I install one as is needed and tie the second out of the way until needed. I know that this belt does not get extensive use but just thought I'd throw it out there. Den
Own 5 720 garden tractors with associated equipment,1 620 garden tractor, 4 wheel 20 2-5015, 5020 and associated equipment and 2 electric forklifts. |
N186364
I did look at the " allcropharvester.com " web site and the auger belt is listed with a part number but also ( very helpfully ) the letter/number combo for this belt which is B61. Thanks.
TomYaz
NP. Torgue? Dont think so on the torque---I have never heard of such a requirement
Post Reply | |
