B Allis clutch
Parris001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Topic: B Allis clutch
    Posted: 27 Mar 2020 at 11:15am
I'm slowly working through small issues with Papaw McDaniel's Allis Chalmers model B. This is a very rewarding project.
The clutch engagement on this thing is BRUTAL! There's a very very fine line between engaged and disengaged. Doesn't offer to slip at all, I've pulled a very steep hill in third gear and it just gobbles it up. I want to make it softer but not at the risk of making it start slipping
It there an adjustment?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 12:16pm
The shop manual should have the details you need.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 4:42pm
My guess would be the disk has oil on it. Even out of adjustment it should be a smooth engagement.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 4:47pm
Are you sure you didn't put the clutch disc in backward?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 4:57pm
I've never had it out. And as far as oil on it.......... she don't leak oil all that bad. Tomorrow I'll crawl under it and have a look
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 6:34pm
I'm thinking that the clutch face is worn out and what is left is grabbing.
Dusty
