D17 Series 1 vs Series 2 hydraulics
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 1 vs Series 2 hydraulics
    Posted: 27 Mar 2020 at 11:11am
Hey Gents-
I have a D17 Series 1... has lift arms, and a currently unused outlet.
I'll be mounting a low-vol/high pressure loader with hydraulic curl that is in full op on a Series 2, using all the OEM hydraulics.
My question is... how are the Series 1 and 2 hydraulics different?  is it just the presence of a selector valve, or a second control, different column, double-acting valves, etc?
And finally:
Is it a reasonable possibility to adapt Series 2 hydraulics to a Series 1 tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2020 at 11:20am
Series 1, 2 and 3 are essentially all the same. 3700 psi max pressure at about 4.5 GPM. Anything more than the two levers on the steering column are added on, either factory option or homemade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2020 at 9:14am
Hmmm... okay...  then the loader probably has a selector valve bolted on at the operator's station somewhere.  The lift cylinders are single-acting, but the dump cylinder is DA.  Hmmm... well, the price is right, I'll figure the rest out.  I was thinking that I'd seen extra outlets, possibly a selector valve or similar on other series, and did not know if they were factory or added.   Thanks!  ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2020 at 10:32pm
this is what he had on the Series II.  I'm certain that this is some sort of Allis setup, but I'm not certain wether it was a factory option for the Series II, or dealer-installed, or a combination of Allis and other parts, but the script on the controls, and on the hydraulic outlet housing all looks 'company' to me.  Can anyone provide enlightenment on what this is, and where I could find this same setup to install on my Series 1?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 7:09am
3-spool valve to the left of the seat was an option. Could have been Factory ordered OR FIELD installed.  Allows operation of 2-double acting cylinders at 2,000 psi. Requires locking the Lift/Lower lever on the steering wheel in the "UP" position for it to work. You can also operate the lift arms from this valve too and there is a lock for that spool to leave it in the raise position all the time. There is a relief valve that is adjustable for using 2,000 psi cylinders or A-C 3,000+ psi cylinders. The "Transport Valve" behind the seat was also an option that was usually included with the 3-spool valve accessory. Hard to find, but a junkyard is where to start looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 3:19pm
Perfect, Thanks Doc!
I'll go hunting.  If anyone has any of these lying about, and would be willing to part with them, please let me know!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 9:20pm
Mount a crank driven pump on front of crankshaft, then use the fender mounted valve and have a good live hydraulic system.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2020 at 10:53pm
Actually, Mack- I have a front coupling installed, and extension shaft, and pump waiting...  that valve combination, and it's mount would be perfect...
