Help Wanted - Rear Wheel Bearing
mas123mas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mas123mas Quote  Post ReplyReply Direct Link To This Post Topic: Help Wanted - Rear Wheel Bearing
    Posted: 10 Feb 2020 at 12:49am
Hi All, New to the group, as I have just purchased a 1948 Allis Chalmers B, that need a little work.
I am needing two new Rear Wheel Bearings, has anybody a make / part number for these, or the sizes and description.
I am wanting to order the spares before I remove them ideally.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 12:42pm
Welcome to the forum. There's some good info on here. Post this question over in the farm equipment section for better results
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2020 at 1:11pm
Rear Axle/Final Drive:
Axle Seal- CR #25043
Axle Speedi-Sleeve - CR #99248
Outer Axle Bearing Cone - Timken #368A
Outer Axle Bearing Cup - Timken #362
Inner Axle Bearing Cone - Timken #14138A
Inner Axle Bearing Cup - Timken #14276
Bull Pinion Seal: CR #13900, National #450456
Bull Pinion Bearing Cone - Timken #14138A
Bull Pinion Bearing Cup - Timken #14276
Transmission & Differential:
Differential Carrier Seal - CR #11343, National #410163R
Differential Carrier/Bull Pinion Speedi-Sleeve - CR #99125
Differential Carrier Cup - Timken #25520
Differential Carrier Cone - Timken #25580
Input Shaft Cup - Timken #15250
Input Shaft Cone - Timken #15120
Input Shaft Seal - CR #11800, National #450162 (471765)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 2:36pm
Steve, are these the same for the 'C' ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2020 at 12:38pm
as far as i know the B and C use the same bearings in all locations...... above is what i have used on the B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mas123mas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 10:58pm
Many thanks.
I have now ordered the parts.
