Gas D 15 manifold
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Gas D 15 manifold
    Posted: 10 Jan 2020 at 3:37pm
Pulled mine today . Have a new one on the way . One of the holes has bad threads . It's in the water jacket , of course . Had a bolt wrapped with Teflon tape in it . Anyone know of better fix ? I did order a stud to replace the bolt . Don't wanna pull the head if I can get by . Thanks
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 3:43pm
Try a small amount of hi-temp epoxy and use a release agent on the bolt.   Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 3:46pm
Needs to be a stud so it runs out of threads when you screw it in 1/2" and put some kind of dope or Teflon tape on the threads. This is of course as long as someone hasn't oversized the hole in the head from drilling out a broken off stud from a previous repair ???...…….
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 4:04pm
Threads are there but pretty wallered out . Ran my 3/8 16 tap in and out with my fingers . Thanks
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 7:45pm
You might have to drill it out and use an insert and some high temp sealer.
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 8:23pm
Any kind of epoxy or sealant that can withstand the whopping 15 ft-lbs of torque, should do the job... If the stud pops out, Heli-coil time...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 6:15am
May try the high temp jbweld I have when I get my new studs . Didn't realize it was only 15 lbs . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 8:31am
Checked my book and it says manifold to head torque is 25-30 lbs . Still less than I thought . I'll be happy with 5 lbs and no leak . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 7:53am
Missing 5 out of 8 studs . Have them on the way . Since the second stud from the front is in the water jacket I assume that the next to last stud is too ? Plan to put thread sealer on both . Should the other ones be installed dry ? Maybe a little antiseize ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 9:18am
ACinSC,
 I had two bad threads in the head on a 45. it was off so went to the shop and he put a new thread insert in each bad spot. This was 1/8 inch larger per side than the thread. I believe it screwed in with sealant and prick punch to lock it. It leaked just a little till the engine cured the sealant and hasnt leaked since. It was more work but saved the head.
 I used sealer on all the studs when installed.
Good luck on your project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 10:33am
Thanks Chris !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 1:33pm
Anyone know why threaded studs are so expensive ? 5 studs cost me $73 . Guess I should have asked the price before I ordered them . Oh well . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 1:39pm
Can I ask what's the part number for the gasket set. I don't have my 15 book near me. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 1:46pm
AC,
guess I havent priced them lately but that seems high too?? I do like to put new ones in place. Your doing the right things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 2:05pm
Who are you getting them from?  I don't think I paid that much for ones from AGCO last time I got some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 2:23pm
Rather not say where I got them . Don't wanna bad mouth anyone . Just seems kinda high to me . Only got a manifold gasket but I can find the number if you need it. Thanks
Edited by ACinSC - 17 Jan 2020 at 2:29pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 2:30pm
JB Weld sells a putty type glue for wet areas.  It comes in a cylindrical tube.  You cut off how much you need and then knead it.  it worked great on an oil pan I fixed so it should work for your use.  It should also make new threads once it's cured.
Edited by john(MI) - 17 Jan 2020 at 2:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 3:39pm
Thanks John . That sounds like what I have . Hope it works for me .
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 4:12pm
Mikez
Head Gasket prior to Eng. Ser. 124338 4512323
             after    Eng. Ser. 124338 4514395
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 5:17pm
Everyone would like to know who's overcharging for parts. Or is it just AGCO has raised prices on parts they don't want to handle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2020 at 6:00pm
I would think even the expensive auto parts group, locally wouldn't charge much more than $5 per for those lil studs...Wink
This page was generated in 0.114 seconds.
