Dole 4000 Tester ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Dole 4000 Tester ??
    Posted: 08 Dec 2019 at 5:59am
We use a Dole tester with the large rotary dial that is graduated into the moisture percent which I will call "points". There is a mercury thermometer that tells you to add or subtract a certain percent depending on the temp. Is the thermometer's percent considered a "point" or a percentage of the big dials' number ?? The manual is not very clear to me Confused .Thanks
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 8:57pm
If its like mine (dont remember the number) there is a calibration scale in the drawer. Like x temp you add 1% moisture and y temp you subtract 1%.
