AC 7080 battery cable |
twinsonfarm
Silver Level Joined: 05 Aug 2019 Location: IL Points: 129 |
Posted: 02 Dec 2019 at 9:22pm |
Does Agco still make or offer part number 70267263 (upper battery positive cable) for AC7080? Is there another option for the dual battery positive cable from another source?
Edited by twinsonfarm - 03 Dec 2019 at 10:31am |
Ron(AB)
Orange Level Joined: 27 Dec 2009 Location: Alberta Points: 943 |
You can make them yourself is the other option.
You do realize that any 7000 series (except 7000-10) would have the exact same cable??? The 8000 series cable would allow you to use bolt on battery posts but still work. |
twinsonfarm
Solder or crimp?
Lonn
Crimped with the proper tool is sufficient. The guy I went to for generator, alternator, starter work used to lend me his crimping tool (gonna miss him) so I could make up my own cables as needed. Put shrink tube on to seal the job.
Wink I am a Russian Bot |
Lonn
And when I used to work at the CaseIH dealer we'd use the hydraulic hose crimper which worked super nice.
lowell66dart
Orange Level Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
NAPA has the solder ends and solder pellets but they are not cheap.
I use a place call Dell City when I stock up on things. Making your own is the way to go. If you order anything remember that on most batteries the positive and negative terminals are a different size.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
I like solder for conductivity but seem to always cook insulation next to it. Good crimp is fine but I don't have stuff to do it right.
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8789 |
I prefer to crimp and solder the terminals. This assures good contact.
Heat shrink will help protect the connection and make the job look professional. CLEAN the wire and the hole to be soldered in the terminal. 60/40 (60% tin 40% tin) Solder Use solder paste (flux) on the wire and the terminal. {NEVER use ACID CORE solder on Electrical.} Pre-tin the wire before inserting into the terminal. Crimp the connection and then solder. Trim any straggler wire strands. Slide heat shrink into position and heat. There are many good videos on YouTube. Here are a couple. |
Adam Stratton
Orange Level Access Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
I bought a hydraulic wire crimper (cheapy import off ebay) and couldnt be happier. Wish i had done it years ago. I have converted lots of old cables with badly worn clamps to the screw type and am very happy with it
Joe(TX)
On the tractors using post type batteries, I have been using the ordinance type terminals and lug terminals on the cables. This allows me to use stud type batteries if needed and the battery terminal is easy to replace.
fourthgeneration
Bronze Level Joined: 03 Jan 2017 Location: ohio Points: 170 |
I don’t know how much equipement you have but I have enough to justify a set of greenlee crimpers. I just make my own now. With OEM prices it has paid for itself and reduced traveling to pick up parts.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11550 |
We make Battery cables. Any size, any length. Just need the size you need, and the C to C.
Steve@B&B
Orange Level Access Joined: 12 Sep 2009 Points: 19520 |
I never ever used the OEM style cable. Use TWO separate cables, one from each battery + post to the starter stud.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11388 |
X2 on that! Have done that on every set of cables I've replaced in the last 8 years or so. Stuff spins over like I don't recall ever witnessing.
Whenever we converted a 4 battery tractor over to two new 1000 CCA batteries, we just cut off each existing cable and added on new battery post ends.
Toscani NE SD
Orange Level Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
all these posts and nobody answered , yes agco has the cable, i just bought one for my 7080 a couple months ago, it was about $124 if i remember, and its better than any home made thing
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1403 |
My 7080 has 2 cables to an insulated terminal on the starter frame and a copper strap from there to the solenoid post. Separate grounds to frame. Dale
orangereborn
What size replacement cables did you use? Did you always have enough starter solenoid stud for two cables? Have a 7040 that came with separate grounds to the box frame only. Seller warned that they had a lot of starter problems....Thanks,,,,Dale
