New starter switches-junk!
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: New starter switches-junk!
    Posted: 26 Sep 2019 at 11:11am
These things are very cheaply made, broke after one week of use. Is there a kit to rebuild the original?
CA Tractor
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 11:24am
Get a Cole Hersee switch whenever you can.
Edited by DougS - 26 Sep 2019 at 11:24am
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 3:05pm
A lot of general purpose-universal switches are only rated for 5 amps!
Read the specs on the switches if you are re-wiring your way and consider the loads.
Did I see a suggestion not too long ago to route the output of an alternator through the ignition switch? Ain't going to work, for long.
If it is a purpose built replacement part that is failing, then it might be a cheap-o.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 4:22pm
Yes the mechanical switches that attach to the starter and is rod operated are junk. I don't know of anything currently available new that is not made in China for this application.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 4:47pm
I took mine apart and filed the contacts until they were smooth and fully, well, contacted each other.  If there's enough left of the switch, that's an option.
1951 B
chaskaduo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 5:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 7:40pm
Oh, THAT starter switch, not an ignition key switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 10:21pm
I’m assuming for a CA.
1951 B
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 8:23am
I had a similar problem.  Removed the old switch, cleaned all the contact points, and put it back on.  Has been working fine for several years now.
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 8:43am
Steve at B&B Custom Circuits has good switches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 11:14am
The Cole Hersee looks identical to the one I have minus the side terminal. Is that a positive or negative terminal? I could try to clean up my old one, but one problem is the spring and push button is wore out, and binding.
CA Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 11:17am
B,C,CA, Styled WC, WD and the WD45 all had the same starter switch. Well, except for some of early tractors that had an Autolite starter.
Edited by CTuckerNWIL - 27 Sep 2019 at 11:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 12:11pm
Most likely positive, but you can check it with a VOM, and if it's activated only when the switch is depressed, for voltage to something else when starting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 7:36pm
I can see if you're 'whimpy' about pushing on the rod, you'd get a LOT of burning and pitting of the contacts which of course makes it worse the next time you use it. Push hard and hold.... would be my advice.
It's also important that both pieces mate very well ! ANY rough spots and arcing will occour, again , pitting the pieces.
I've always wondered about 'figuring the math' to choose a capacitor to cross the switch to quench some of the arc ( same as points) then something else comes up, someone wants something, sigh...too many projects too little time....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2019 at 8:05am
Steve is right. We still have a pile of USA made switches yet from 25 years ago when I bought out an old Automotive Electrical business. The real way to go is change the Starter motor over to a stud design, and incorporate a starter relay to it like the "D" series Tractors have. No voltage drop, full power to the Starter. Use a good quality starter solenoid like a C/H or SMP version for forklifts and a high amp key crank Ignition switch. I keep all of that in stock...
Steve@B&B
AC Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Guy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 12:52pm
I have an Allis C and have had problems with the factory original starter switch. I was able to clean it up by sand blasting it. You must remove it completely to get it into the sand blaster.
