190XT Tie Rod Removal Problem |
calico190xt68
Orange Level Joined: 12 Jan 2017 Location: Frankton, IN Points: 729 |
Posted: 18 Jul 2019 at 8:26am |
Tie tie rod broke over weekend and I am having trouble removing the stud from the the cast iron piece. I have hit it with a small sledge but it isn't moving. Soaked it with wd45 over night too. Seems like the rubber protector is embedded into the hole but not sure? I don't want to break the cast iron piece hammering on it. I am also having trouble removing the male part from the female part. It won't budge either. I am kind of wondering if I shouldn't just replace the female part though while I am replacing the male. It is probably worn out too. Just asking if there are any tricks anyone knows about to make this happen? My thought was to heat it up and that might burn the rubber boot that surrounds the stud? |
80 7010 w/Cab, 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2210 |
Heat will help, don't think a fork will get under the remains to wedge it out of the hole, but might try it. ---Might try a puller and press from the bottom side to force it to loosen in the taper hole. If all else fails, I always went for the heat as last resort.
Lonn
See if a fork can get under it or someway to put upward pressure on it..... a bottle jack?..... and then give the end of the cast iron a good rap with a heavy hammer. Should pop right out.
Wink I am a Russian Bot |
Rick
Orange Level Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3641 |
I always just take the nut off the tie rod and jack the tractor up...it'll pop loose sooner or later with that much weight on it. Never have broken a steering arm yet either. Those things are some hard stuff! Rick
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1352 |
I hit it on the side of the arm towards the spindle. Hit it hard and it will come loose, did a 6060 and a 8010.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8013 |
Remove nut,turn spindle so you can hit the tie rod end straight on with a BFH. Few good whacks will release taper. Otherwise you remove wheel and use BIG hammer on one side and whack it on the other with another big hammer.
Joe(TX)
PB blaster or Kroil will work better than WD40.
I used a tie rod removal fork on mine. There is also a tie rod removal tool similar pitman arm remover.
calico190xt68
Well, I used the jack method and used a hylift Jack on the bottom of the bolt. Got the wheel off of the ground. It did not release though. I let the jack down after about 3 minutes. Removed the jack and hit it twice from the bottom with a small sledge hammer. It came right out. The stud was bent to one side so might have made it stick. I see no easy way to get the male side separated from the female side. I have decided to buy female side since I can feel some slop. I paid $80 from agco for male side. Noticed that all states ag is selling both sides for $42. Going to pay $19 for female side plus shipping. Is the agco version worth another $45 for female side? It is still an inexpensive fix compared to most. If the extra $40 is worth it then maybe I should go that way. As always, appreciated everyone offering up the advice. I was attracted to the jack because hitting things with a hammer has screwed me a free times.
allisrutledge
Big hammer is my best friend. I would think agco parts should be better but they probably came from the same production line as the cheaper ones.
Lonn
When I worked at the Allis shop the foreman told me you can do more harm if your hammer is too small. I've kinda stuck to that thinking for most things needing a hammer.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
I replaced a tie rod on a 200 allis this spring with the new setup from All States Ag PArts. I would NOT reccomend their tie rod! Where the male end slips into the female end, the tolerance is wayyyy to big! You will tighten down the clamp and the tie rod will slide out when you steer the tractor. I had to put a second clamp on it and grind the clamp gap bigger and it was still questionable. Get the AGCO one. If it is like the original size, that would be the way to go.
www.awtractor.com
Joe(TX)
I had to use the clamp off the old tie rod. The ones on the aftermarket ones are not heavy enough. Like was stated earlier, the aftermarket rods are too loose also.
bradley6874
Spend the extra and get Agco also unless the other side has already been changed do it also as all the slack won’t take long to Kill the other one
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Dang guys , crank down on the bolts and a spot weld will hold it
200 10and20
Orange Level Joined: 20 Jun 2019 Location: Tim Buk Tu Points: 217 |
Fix it with Agco parts and do it right Mickey Mouse parts and Mickey Mouse repairs will get you or someone else hurt or killed!!
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4641 |
A ball joint wedge or removal tool depending on your description worked for me. I did find, that its less expensive from Agco to order the entire assembly than to order each side. I was going to replace both sides at the same time while I had it apart.
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10557 |
The easiest and safest method is this: Loosen the nut on the stud several turns. Jack some force against it,just steady pressure, Then hold a 3 lb hammer against the steering arm solid on one side, hit the other with a hammer. It will come right out. The nut keeps it from hitting you in the head. Never had this to fail, the hammer lick temporarily eggs the hole to break it loose. HTH Tracy
FREEDGUY
Kinda glad some of the advice isn't in the OP manual
calico190xt68
I bought the agco version. Should arrive Tuesday. I will look at other side and see if I should replace. A really rough hay field created this problem. One thing I noticed was that the replacement has a grease fitting whereas the old one did not. The other side has a grease fitting. Thanks for all the advice.
