2000 GMC electric motor keeps running |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9273 |
Posted: 21 Jun 2019 at 5:00pm |
My truck has an electric motor that keeps running. It bolts to the frame left of the transfer case. It looks like brake lines going to it.
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
If that is brake or ABS related have you checked the brake fluid level?
1957 WD45 dad's first AC
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77842 |
Steve M Ind
Bronze Level Access Joined: 12 Sep 2009 Location: Springport IN Points: 58 |
The relay is built into the ABS box. The relay is stuck on and needs replaced or it will run the battery down. Need to replace the controller part of the box. Have seen this many times.
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5639 |
My '99 Chevy had same thing happen, but the ABS pump kicked on, blew the rear brake line out, and totally emptied the master cylinder... At 45mph... With a flatbed trailer in tow... with 4600lbs of lumber on it... ...heading for a stop sign.... at a 2-way intersection... ... with two tractor-trailers full of grain coming one direction ...and a five-axle dumptruck full of gravel coming the other way... I was fortunate to have presence of mind to slap the trans into LOW, then grab the trailer brake controller and squeeze it to full, while flipping the GAIN switch to max... I got stopped about two feet into the intersection... all three drivers saw my trailer tires smoking and knew what was up... they moved over JUST ENOUGH to keep me alive. Cost of replacing that ABS pump (after lifting off the cab) was seriously in excess of the value of the truck, so away it went.
desertjoe
Hey Dave Kamp,,,glad to see you safely back home from the Great Southwest snake country,,,,, Dang,,that sounds like you had you a close call,,!! You know,,them vehicles always seem to gain speed when them brakes fail don't they,,,?? There may be one of them trks up for sale up around the Eurica Springs area,,,,,,,,Chit,,I'm outa here,,,,,
Thad in AR.
I checked the fluid and it was ok. I drove it around the place and the brakes work fine with it unplugged. I haven’t had much time to mess with it.
Steve M Ind
You can unplug it or just pull a fuse, Will not have the ABS function but will have normal brakes and the pedal should feel normal.
Thad in AR.
Is it safe to drive to work? They feel fine. |
Steve M Ind
Some of my customers never fix them. Just drivem with the ABS light on.
