Wd front end to wc rear end?
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: Wd front end to wc rear end?
    Posted: 28 Sep 2018 at 7:22am
I got a off qeustion for the guys
I have a styled wc that has been all re fabricated for a huge stump grinder it runs terrible motor was froze and hurt by someone leaving water in it
I put mendite solution in it and sealed up all the cracks to keep the antifreeze out but motor is really tired uses about a quart of oil a hour when grinding
I have a good running wd engine
But was wondering if i split the wc rear end if i could mount it the wd frint end ?
The wc uses a homeade pivet arm to disconnect the engine and transmission shaft and then has a pump run off the belt pulley that is on a gear to move the tractor cery slowly with the hydraulics when im grinding with it
The while rear end of the wc is welded up to support the grinder so i have to use that
But from the frame rails where they mount to the rear end all the way to the front end looked the same and the wd gas perfect sheet metal and front tires and motor so i was pondering splitting and trying to make the wc reaeend work with the wd front end
~AMP~
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 7:28am
It would be easier to just put the WD engine into the WC. Look at the difference from the bellhousing and back. You'll see why.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 7:35am
Ok thanks i dont have a wd here to libe them up and look everything over
I will swap motors and front ends too being that the wc has only 4 bolts holding it in and a very wore out narrow front end
And the wd one is line new yet
~AMP~
brkfldj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brkfldj Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 8:47am
I've got no knowledge to help with your repair, but I'm curious about your custum made stump grinder. Pictures would be appreciated. There are many "natural" engineer's talents displayed by these one-off machines.
Jim
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 9:04am
the Engine and front end will bolt on but every thing from the bell housing back is very different.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 9:07am
The rails are not the same, I'd just use the engine and front steering gear off the WD in your WC.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 9:45pm
This will work. Neighbor has a tractor setup this way.
This page was generated in 0.246 seconds.
