WD industrial model?
59f100292 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Topic: WD industrial model?
    Posted: 29 Aug 2018 at 12:54pm
I went to look at a WD for sale a few days back and quickly noticed the following oddities:
- non power shift rear wheels
- no PTO
- no handclutch
- No hydraulic system at all. Pump, lines, rams, arms, or controls.
It’s my understanding these were all standard features on the WD
The clue that makes me think it came from the factory this was, and not just cobbled together from ofther parts, is that on the steering column, the cast semicircle just in front of the throttle and hydraulic controls was cast from the factory as just a 90 degree arc on the throttle side, no sign of their ever being the left side arc for a hydraulic control.
After a phone call with Bill Long we were of the opinion that it may have been sold that way from the factory to an industrial application for nothing put pulling.
Has anyone heard of such a tractor? Any other ideas what it’s history may be? Is it worth anything?
Unfortunately I am looking to buy a tractor that will at a minimum run a bush hog, so this one is not of value to me.
If it turns out it’s some rare specialty I may go back and make an offer anyhow.
Advertised as a 48’ model. I didn’t bother to write down the serial number as I was not interested in the purchase once I saw it was missing PTO and Hydraulics. The current owner uses it to pull a wagon on Halloween and wasn’t aware the missing features were significant.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 4:38pm
Go back and take some pics of it, I would like to see it. I have never seen one like that before
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 6:24pm
Your dealer was able to delete one or even all this list (maybe even more) from the factory, shift rear wheels, PTO, hydraulic system, hand clutch, lights, starter, generator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 6:50pm
I know WD45's were shipped to Henry mfg, for mounting loaders and backhoes, so it wouldn't me much of a stretch, to have WD's as industrial units...Wink
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 7:11pm
What I would find to be the real head scratcher is the steering column throttle bracket. Be it a purpose build industrial model or a standard farm tractor w/dealer deletes, why go to the bother of creating a separate part for either reason.
I am still confident of this;
Wait for the Lord;
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 8:13pm
I've seen the half throttle quadrant but only on pulling tractors where they were cut off to save every ounce possible
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2018 at 10:00pm
The parts for such a tractor are in the regular parts book. Covers, hand clutch delete coupling, etc. I did not notice the half quadrant, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 10:49am
Delete
Edited by 59f100292 - 30 Aug 2018 at 11:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 11:06am
Edited by 59f100292 - 30 Aug 2018 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 1:08pm
Why would anyone do that? Took a modern tractor back to the stone age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 2:45pm
Just pure speculation but after comparing photos I could believe the wheels and rims are straight off the WC.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 3:21pm
Anyone could have striped this down .
nonetheless ,still dead.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 3:48pm
Wheels can't be.  WC was 6 hole, WD was 8.  I'm not sure what that thing originally was, but they did a good job painting it.
AaronSEIA
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 5:04pm
Pullers do it all the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 6:33pm
 Gary ,after looking at it a few more times ,I would say that it is nothing less then a puller . LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 7:16pm
AaronSEIA
You’re right. I double checked. It has 8 lugs.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:42pm
I agree about it being a puller. Using 3 pt top links for adjusting height of hitch, is a dead give away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:50pm
Couple other things that stick out is the location of the light switches. Also notice the spacers on the hitch. Stack of washers and oversize nuts. If that was factory, those would either be solid plates, or the brackets would have been made longer so no spacers would have been needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 59f100292 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 10:01pm
Without a doubt the drawbar is not original. He rewired the electrical harness to add a fuse (seen on top of the box) and add lights for the wagon he pulled neighborhood kids in at Holloween. The current owner did those switches on the side of the box unrelated to tractor pulling.
All that being said, it does all seem to point to a past puller that someone retired to suburban duty.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 2:56pm
After further research by examining Pop's Price Book (1960) tractors could have been shipped from the factory as BASE TRACTORS.  That means that the basic tractor less the PTO, Hydraulics, Hand Clutch, and the spin out wheels could have been purchased.
Looking at the pictures this is one of those BASE tractors.  Why someone would want one is beyond me.
Even though I sold them for the life of the unit I was not aware of this option.  In fact, having handled many WD tractors new and used I NEVER repeat NEVER saw this unit.
Very interesting.
Good Luck!
Bill Long
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 3:13pm
Im on the tractor puller band wagon as well.  Ive it were a standard tractor it would still have a regular drawbar.  I also noticed the shutters are also gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 7:56pm
Yea looks like something I would do! Except for the skulls, Not into that!
Screams puller to me!
Bill, I think you can rest easy on this one.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 8:20pm
Hand clutch is not there, I'd bet money it's a solid coupling under the cover...
When I first read the opening post, puller was the first thought that came to my mind...now that I've seen pictures, pretty darn sure puller...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 9:20pm
The cover for pump don't look like a factory cover would. Looks home made.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:04am
The factory cover was cut in a curve similar to the one in the pictures.  I agree though, it doesn't look quite right.  Cover was part number 70222529.
AaronSEIA
