8550 water pump
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: 8550 water pump
    Posted: 14 May 2018 at 6:51pm
Looking to buy a NOS or rebuilt water pump for a 8550 (731 engine). Anyone have one or know where to find?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 8:15pm
Hope you have better luck than I had last spring. I had 9 days of down time due to a water pump out on my 8550. Hi-Capacity had a re-built one, and I got it the next day, but it had an improperly installed seal, and leaked as bad as the one that had gone bad. Things went down hill from there. Possibly they would have another re-built one ready to go now, Darrel
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 8:55pm
Did you find a replacement or have yours rebuilt?
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:07pm
I rebuilt mine myself, got the parts from AGCO probably ten years ago. It's the same pump that used on the 844 cubic inch engines. If the parts are still available from AGCO it's not all that bad to rebuild. Might also try Minn Par. Good Luck! Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:24pm
Might also try ILLINI Construction Parts, their add is on the parts and service page. Been awhile but good people to work with then. Good Luck!, Mike
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 12:34am
Mark Heitman Durand Wisc
Mark has always had one on the shelf when I needed one, and he shipped it out quick to me.
Edited by Amos - 15 May 2018 at 7:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 5:43am
I ended up getting a used one from a salvage yard. Darrel
Transaxial View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Transaxial Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 7:39am
It's been a lot of years since I worked on a water pump for my 8550 but I think I still have a seal kit on the shelf. Those seals are very common or standard should I say. Like either a 5/8" or 3/4" shaft size and the OD is quite common as well. Check with a supplier for electric pressure system pumps that are common and current models.
To some of you guys still running these tractors would you be interested in buying an 8550 that has an 855 Cummins NTC350 in it? Really made a better tractor out of it. Fuel consumption is so much better on the Cummins it will pay for itself in a couple of years compared to the 731. I used to find the 731 burned 12 -14 Imp gal/hr and the 855 doing the same job was 9 - 10. The difference was being out of fuel on the first tankful by 4pm or working till 10pm with the Cummins. Also with the Cummins there is no issue getting parts. We went through the tractor in our farm shop last winter and fixed all the little things like lights, new A/C compressor, and a couple of oil leaks and did a major paint job on the old girl. Looks like new and actually runs like that too. It is a very reliable tractor. I have retired and just want to see it go to a good home. I bought this tractor in 1986 and I have spent a lot of time in my farming life with this tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Transaxial Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 7:51am
Sorry! Having trouble posting some pictures of my 8550 that I would like to sell. If any of you guys want pics or more info PM me your email address and I will send you what you want.
This page was generated in 0.373 seconds.
