Bought an educational tractor
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: Bought an educational tractor
    Posted: 01 Nov 2017 at 4:33pm
And B makes 3. Finally found a B I wanted to buy. I has it's share of issues so I will be asking(begging) for help in the future. For now it is put away in a friends pole barn. Question 1 What are the custom from rims off of?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 4:37pm
Looks like rims from a car to me, like what you'd find on a spare.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 4:41pm
That's what I thought.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 5:40pm
Those rims might be off a trailer.
Dusty
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 5:42pm
Those are 5 bolt trailer or light duty pickup rims.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 5:59pm
They are off a 3500 lb. rated trailer axle.
Gary
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 6:04pm
A 12 inch garden tractor rim will fit a B- C hub !
turbocharged
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 6:14pm
I have your shop manual on line at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Many tractor front rims are standard SAE ag rims, used on implements, wagons, trailers and sometimes cars and trucks. And were available from multiple manufacturers when the B was built and still today.
Gerald J.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2017 at 6:42pm
Thanks Gerald. I saved the manual. I think I may have a hard copy also for my C.
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 7:40am
sounds like this will be your first experience with auto tires on the front.
it will take some getting used to.
since they don't bite into the soil as well as the original ribbed front tires, they have a tendency to slip sideways a little on turns - especially sharp turns - making those turns a little wider than planned.
spooked me out at first, but you can get used to it.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 11:35am
Buying an educational tractor works like a charm. It is one of the most magical tractors ever built. Over the years I have watched people buy an Alice Chambers B and within weeks make it became an Allis Chalmers B. Then within months was a fully informed mechanic that could guide a newbie thru a complete overhaul.
Actually you can have fun learning while rebuilding these little tractors. You can learn more digging into the fine detail of each little part and question why.
Good luck.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 11:54am
The rims on a B or C are 5 bolt on 4 1/2 in bolt circle. The same as Ford or Dodge used in the 60's, as well as 3500 lb. trailer axles. Standard ag 5 bolt are 5 in bolt circle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 12:05pm
A new toy!!!!  You trying to catch up to me??  LOL
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 5:38pm
Nice.  I love seeing another one coming home.  Good luck with the "learnin."
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 6:08pm
Good luck.
Very well said, Dick! That's a majority of how I learned what I know now.
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 6:34pm
Rims off an old AC hay rake fit my CA.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2017 at 7:50pm
Ted you are way to far ahead of me! I think it will be a learning experience, but I have wanted one to work on as I can.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 4:02pm
Would CA front rims work on this?
