190XT narrow front
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 190XT narrow front
    Posted: 05 Mar 2017 at 8:40am
I know this is a long shot but does anyone have a narrow front end for sale for a 190XT? I would like to convert mine to a narrow front. Are there any other series that used the same front end that may also work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 8:53am
Definitely a long shot.  Good luck with that.  Early 180s apparently had an internal steering cylinder in the front casting for this purpose.  Don't know if it would fit an XT though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 12:45pm
180-190-190XT. Lines will differ on 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 12:51pm
I don't know what all is involved withe swap, if anyone has a narrow front i would like to have some up close pictures please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 12:53pm
The whole cast iron front support under the radiator gets swapped when going to a NF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 2:11pm
Thanks DrAllis, I thought that would be the case. So are you saying a 180 narrow front would also work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 2:32pm
Yes they will, 180,190 all the same size, four bolts hold it to the frame and other stuff has to be taken off but it's all the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 2:39pm
Thank you, happen to know if anyone has one for sale?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 4:50pm
If I may, and I am sure I will be blasted for offering a different opinion.
There was only one front housings for the 190/190xt tractor.  That being said, the tractor could be ordered with the front support "loaded" with the power steering ram inside, misc. lines a steering spindle etc. this version of the front housing was called an "Interchangeable front axle".  The other option was the same front housing, missing the internal parts, replaced with an external mounted steering cylinder, and a steering arm pivot mounted on the front end assembly itself under the oil pan.  The latter is what you find on most tractors, likely because it was cheaper, and by that time most all row crop tractors were running wide fronts, with few narrows left in the world, so what was the point, likely a question asked by many a farmer ordering the tractors new.
The front end housing with the internal steering 1. was a better design in that it kept forces off the front end which IMO added to breaking so many front ends, or could be the sole reason.  2. allowed the use of the narrow front wheel assembly.
We have an interchangeable front 190xt, been a family tractor since new, have the receipts from the family dealership, and know it's history.  Yes we have the narrow front to got with it, and no it's not for sale! Shocked  If we could find a real single front, that would be awesome, but never going to happen.
Still in use:
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 6:41pm
A guy about 60 miles North of me has one but don't think he would sell it!---with narrow front you could probably use the late ac mounted corn picker. thanks; ac fleet
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 6:57pm
 First wondering is, Is it possible to "barrow" a narrow front for a 190 and use it to make some green castings and then get them machined out for those that want the front support...
 Which leads to the second wonder somebody asked awhile ago,.. would it be possible to make an adapter that would accept the  JD rollomatic off of a JD 4010 or 4020... or 730... might be easier on the front support.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 7:57pm
I have a Narrow Front OneNinety. The power steering lines run along the left side above the removable side panel. The standard wide fronts have the lines and hydraulic hoses run down the right side frame rail to the steering cylinder. Interestingly the BeachMaster OneNinetys have the internal steering convertible front casting. Because of the short spindles and the job application it was likely so the hydraulic lines would not get snagged on any beach debris.  Also not for sale!
Edited by Calvin Schmidt - 05 Mar 2017 at 7:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 7:18am
The "inter-changeable" front support was an OPTION and cost more $$$$$$$$. Allis-Chalmers probably sold more tractors with wide fronts than anyone, and partly because of lower cost. Broken wide front axle frames at the left rear corner could have been eliminated with 5 lbs of extra steel bracing and interestingly only about 50% ever break. Makes me think those that were broken were somehow used more stressfully than others ?? I'll take the external cylinder any day over the internal design for simplicity and ease of repairs when needed.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 9:14am
We (me) dropped our XT wide front in a blown out tile hole and broke the left rear corner.At night plowing new rented ground. Dad just laughed and said"the worst thing that ever happened to agriculture was putting headlight on tractors.Now you can hire the town drunk and farm twice as much" I dont Think he meant me...........?????
Edited by JayIN - 06 Mar 2017 at 9:19am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 10:18am
When I lived out in Colorado, there was a blown up 190xt near me that I tried to buy, but they were not able to sell it because of legal troubles I think. It was a wet bolster, interchangeable front end tractor, series 1. Seems like it was a 66 by sn. I have often wondered what ever happened to that one, I've been gone from there for well over 20 years. It had a wide front, and a cab. Was a few miles south of Roggen on the east side of the road. Sat there for years!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 1:19pm
I have been reading this post with interest as I like the looks of a narrow front 190.I just went to the AGCO site and printed the parts page for the narrow front 190. The design and looks of the front boltster is almost the same as the Deere used in 3010,3020,4010 and 4020's. I couldn't believe how close to the same it looks. Could someone tell me what the width of a 190 is? Are the xt's the same? I have several Deere steering assemblies and do believe they could be made to fit. I would even donate one to someone who could do the machining to make it work.They would be heavy to ship.Unless the Deere is to wide I think it is a very doable project.  Does anyone know the height of the Allis pedestal? I have a few Deere rollomatic front ends that I could measure as well. Someday I want a 190 and if this project will work I might sell my D15 and start hunting for one. Anyone with any ideas post back. Tom
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 1:29pm
I had a customer who used one out of an oliver in a 190.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 6:38pm
180/190/190xt is 19 1/8 inches wide inside the frame rails Tom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 6:39pm
There are 2 different types of front bolsters for 190s. The solid one, or the interchangeable one.
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 6:58pm
I noticed the same. On my 190 XT I changed the front end out last winter. Old one kept busting on both rear corners. Hadn't been abused in its life. Couldn't tell how many times grandpa, dad and I each welded on that axle
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 7:02pm
The 3020-4020 steering measures in at 18 7/8 so it would fit inside the frame rails. I really think this is a doable project. If I can find a cheap 190 latter this summer I might just give it a try. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 8:02pm
The whole reason I started this post is because I love the look of the narrow front. Our ground is for the most part flat. I know the dangers of the narrow front, had a neighbor die in a roll over on a Farmall M. There have been lots of great information passed on of which I appreciate. Just a shame they are imposible to find. I have access to an interchangeable front, I am assuming all I need is the pedestal.. I haven't seen it yet so again I am assuming. I heard the 4020 may be a possible route but haven't heard of anyone actually doing it. I have done some calling around but haven't had any luck in finding a pedestal which is why I made the post. It's on my wish list but not a necessity. Thanks to everyone for their imput.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 8:12pm
Tom if you find that the Deere setup would work I would be interested in your offer. Where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 8:35pm
I am in southern WI. Buy the way with your address do you know Allen Summers? Years ago Dad sold him maybe a dozen or more allis tractors. Tom
190man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 8:42pm
I have a 1965 190 with a interchangeable frontend.Has widefront wouldn't mine having a narrow front myself'
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 8:56pm
Yes I know of him. Lives about 15 miles away in Luray Va. He has quite a few AC's. our area had quite a few AC dealers. Local one was Louderback Implement. Kenny Louderbacki sold the dealer to his son. still pulling, I think he is 76 years old now. He is still quite the collector and a good friend of mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 9:00pm
My one XT has the interchangeable bolster but I too need the pedestal narrow front.
 Last year I had a chance to buy some rollamatic narrow fronts and they went for cheap... and I didn't think about retrofitting them to my XT. Angry   Now I need to keep my eyes open the next time I see one for sale...
 Got a sad story, about 1993 I was in a fellows private junkyard and he had a couple old WC tractors taken apart, one with a scintella base mag mount, and another was a 36 model. he also had several narrow front pedestals for D15 / D17 and one solid curved orange hunk... and I was on my way out when I spotted it. Thought I would ask about it and the WC tractors the next time I was in the yard...  Yea, went back in awhile later and he had loaded it up and hauled it to the big scrap yards.  ARRGH and so were the WC's.  I asked why did you haul them pieces away? "oh. they were in my way". DOUBLE AARGH!!!   And now I don't remember what we had gone there to get the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 9:22pm
Alot of them got scrapped in the years before collecting became an art of preservation of the good stuff!
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 11:32pm
Any info or pics of how the Oliver narrow front was made to fit....I have three 190xts here now and two Ollie front pedistols from 1850s sitting in the shed.   Might be a fun project.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:14am
Well, I do not believe the front pedestal will fit from an oliver to a 190, the center turned and the outside is bolted solid where as the 190 /180 were solid cast peds and bolted to the flange under the bolster that turned.
