180 allis Chalmers questions |
keith wd
Silver Level Joined: 17 Nov 2015 Location: michigan Points: 56 |
Posted: 19 Feb 2017 at 1:33pm |
Working on putting 180 back together and trying to get the troque tube back to the transmission and trying to get the bushing to slide back into the hi and lo and the tractor will not go back together all the way what could I be doing wrong the bushing will not go into the hi and lo even with force?
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8032 |
was this bushing replaced?seems I remember about that having to be "sized"after installation
keith wd
Yes was replaced how did you size it?
MACK
It is a bearing so no resizing. Make sure PTO is not stopping it. Make sure piglet bearing did not come apart. How much does it lack going togather? MACK
Lonn
piglet bearing? Never heard that term before. Is that the needle bearing?
Wink I am a Russian Bot |
MACK
Big fingers, little keys= piglet PILOT. MACK
Lonn
Ah, I thought I was out of the loop on something LOL
Orange Level Access Joined: 12 Sep 2009 Points: 19588 |
Never replace the brass bushing in the front end of the power director clutch. It has to be machined to a specific size after installation.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7946 |
Get some long bolts and help pull it together,, gently, if there is alot of resistance stop and check things out
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4419 |
I, personally, would never pull one together with bolts. I have used longer bolts as pilot bolts, to hold everything straight, but I wouldn't pull it together.
MACK
Tie down straps work pretty good pulling one togather. Hook battery up and bump it once in a while. MACK
