Coggonobrien's D15 Series III |
Post Reply | Page <1 234 |
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5179 |
Coggon Have you had an opportunity to use the R/H 3 Hydraulic Levers on your Ser.III while working outdoors in this extreme cold and wearing a pair of insulated mitts ? I think you will find it is a bit awkward. I did a similar revision to my D-12 Ser.III for the 2 R/H Valves. I mounted a Meyers 7' Snow Blade for winter Snow Plowing. The shorter inner lever is for Hydraulic Angle, longer outer lever for raise, lower. Both valve levers are similar to yours, close together, point straight up. It is a royal pain to use the inner hydraulic angle lever on a repetitive basis. I angle plow to only one side of my driveway, so I have to change the angle from right to left and vise versa at the end of each pass. Wearing a pair of insulated mitts, it's rather difficult. I need to rework these levers. G |
Orange Level Access Joined: 12 Sep 2009 Points: 19583 |
The custom live hydraulic system has been thru the summers of 2017-18-19 and 2020. It has never once failed to prime, which was my only concern with the pump mounted up as high as it is. It has worked well with no issues and makes the tractor very universal with modern hydraulics. Now maybe someday we can fabricate a real nice/heavy Category #2 three-point hitch that can easily be converted back to snap-coupler.
allischalmerguy
Orange Level Joined: 11 Sep 2009 Location: Deep River, IA Points: 2864 |
Tom,
I wish I had half your mechanical/fabricating skills! Well done! Pastor Mike |
coggonobrien
Orange Level Access Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1806 |
G,
Tractor doesn't do much during the winter. The hydraulics are used for a deere barge box and a heston 1091 haybine. The Dr is right, after tires are done I need to fabricate a 3pt adapter similar to his. |
JayIN
Orange Level Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Hell, I would just screw on a 2" extension onto the middle lever and be done with it. That should make it easier to find with mittens on.
coggonobrien
I won't be changing or modifying them. If it was a concern I would careful bend them to spread them. As they are now I can run them just fine.
Edited by coggonobrien - 19 Feb 2021 at 11:31am |
coggonobrien
Slow progress
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3158 |
Looking good. Yes progress can be slow. Are rims new? Fits 16.9-28?
coggonobrien
Rims are new from wold. 15" wide for 16.9x26
coggonobrien
Mounted, ready for a drive an retorque. 59.75 center to center.
plummerscarin
Strokendiesel002
Silver Level Joined: 04 Apr 2019 Location: 53158 Points: 252 |
Looking sharp!
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3474 |
Like!
AndrewGubbels
Orange Level Joined: 12 Sep 2009 Location: nebraska Points: 1486 |
Looks like a great project!! Well done!!
Andrew Gubbels
Gubbels Restoration |
