8050 rear lights.
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: 8050 rear lights.
    Posted: 08 May 2015 at 7:42pm
all of the rear lights went out the other night. is there a fuse box, and where is it or is it in the switch?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2015 at 9:43pm
Not familiar with the 8000s, but there should be a fuse somewhere for the lights - check your manual.  If it is good, try bypassing the switch.  If they come on, your switch is no good.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 6:16am
I think there is fuse block between the clutch and brake petals behind the panel. 4 bolts on the panel. Not sure if the light fuse is there, hope so.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 7:05am
Sounds like it's in the switch, loose wire or burnt contact. If any of the front lights work I don't think it's a fuse. The whole light switch is run off of one fuse, I think. I would start by taking the small panel for switch/blinker out and use a test light to see what you find.
Leon B
JET8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JET8070 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 9:46pm
Fuse panel where randy says for low serial number(2-5/16 bolts). All breakers for high serial # in same place. Switch should be fine if all front lights come on. One fuse should not take out all four rear lights and no fronts on stadium light tractor s unless someone has bridged some circuits. If fuses are good check for harness ruby through near power steering motor.
Edited by JET8070 - 12 May 2015 at 9:48pm
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 11:48pm
Check harness connector by the steering motor.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 8:38am
Remove side panels and tin plate at rear of engine. 6 small screws. In behind is a 5 or 6 pin connector. They get old and burn up. After fixing yours, come do our 8070. Lost our rear lights as well.
This page was generated in 0.085 seconds.
