WD45 oil bath air filter screen replacement |
Le Renard Farm
Bronze Level Joined: 19 Feb 2016 Location: Wisconsin Points: 12 |
Posted: 02 Apr 2016 at 7:58pm |
Could you folks help me with my new 1956WD45? I am going to replace the screens in the oil bath air filter but am not sure how to get them out. Does the ring just under the screens come out? I tried but it didn't want to move so I stopped before I broke it.It is a United oil bath filter. Thanks in advance.
Orange Level Access Joined: 12 Sep 2009 Points: 19699 |
You have to break thru several spot welds and then pull the ring free. There are three rolled up segments of wire mesh. I always unrolled each one and washed them out in solvent and reused them.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8172 |
Agreed, Once you are able to get them out, you should be able to clean and reuse them.
Regards, Chris |
Dan73
Orange Level Joined: 04 Jun 2015 Location: United States Points: 6054 |
On one oil bath I took it off the tractor plugged the two air holes and filled it with diesel fuel soaked it for a day drained it out then tapped the assembly on the ground and blew it out with compressed air. I got it really clean. That one went into a different tractor and getting the screens out would have broken the housing for good in that case. On my d17 I did just break the spot welds. Soaking then in diesel works great to clean the screens.
MACK
Role them up, soak them in gas then set them on fire. After they cool, unroll them, knock the soot out and reuse them. MACK |
Well, I spent a lot of time on the last one I did (corn picker fuzz) and this pyro-technique thing sounds like a really good idea !!!!
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
I put the whole assembly in the parts washer for a few days then rinsed it out good before draining and blowing air through it. last thing I did was spray a can of WD40 into it to be sure it wouldn't rust.
1957 WD45 dad's first AC
Le Renard Farm
Thanks everyone! I think cleaning of the screens on my tractor has never been done. The stuff I pulled from the intake tube was half an inch thick. I like fire and future service will probably include flames.
Le Renard Farm
Follow up question. Has anyone tried running the oil for the filter through a paper coffee filter to re-use? Thanks again.
Dan73
Just save used motor oil and put it in there you won't change it enough in a year to use up your used motor oil.
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
It doesn't hold much new oil. Used oil contains acids that may rust components. Change the oil every 10 hours or so of use. If you can't do that then adapt a dry air cleaner to it and set the oil bath on a shelf.
Wink I am a Russian Bot |
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2867 |
I think 10 hours is a little extreme unless its really dusty. I can look at mine in 20 hours and it looks almost new. I would say. Change when you change oil. Chen it some other times to make sure it's not to dirty. You know those old oil quarts that collect around a farm with torn off labels so your not sure what weight they are?? That's the oil I use in the bath
