D 10 parts
AllisTim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisTim Quote  Post ReplyReply Direct Link To This Post Topic: D 10 parts
    Posted: 21 Feb 2016 at 1:21am
Does anybody know if the three point adjustment handles with the wood handles are still around? Could use some if they are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2016 at 5:28am
Tim, I've never seen wooden handles, on the handles.  Got a picture?  It might be a farmer fix...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2016 at 7:36pm
Earlier 3-pt. units had the angled plate type adjuster with the wooden handles, later units were solid bar steel that was shaped for the adjusters.
Have a Series Two that I have been meaning to source/make some of these handles for also so curious if anyone knows where original looking wooden handles can be sourced . . . .
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2016 at 7:53pm
The earlier Series II D10's had the handle for the adjustment arm that you are describing, but the rollers on the handle were cast iron.  If you have a tractor with wood, it is a owner modification.  The later Series II and III tractors had the bent metal rod handle that you also mentioned.  This type is available as a aftermarket replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisTim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 2:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisTim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 2:16am
need to find adjustment handle like on the left side of picture
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 5:30am
Mine are wooden also. I have been looking for one for my left side.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 6:32am
The new style is much easier to use.
Charlie
This page was generated in 0.111 seconds.
