Painting Reclaimed Tractor Parts |
Bricklayer ![]() Bronze Level ![]() ![]() Joined: 06 Feb 2016 Location: Newton, NC Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Feb 2016 at 12:03pm |
I have been cleaning parts on my Allis Chalmers G. Using electrolysis I remove all paint back to bare metal. What, in everyone's opinion, are the best steps to prep, prime and paint bare metal tractor parts? Thanks for the help. ED
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3042 |
I am NOT a body man or painter, but I sandblasted or wire wheeled all parts than painted with self etching primer. You have to use some sort of etcher to stick to bare metal.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3530 |
I have found that any effort towards doing a final fine grit sanding usually results in an excellent binding of the primer to the metal. Immediately after final sanding, tac cloth for any dirt, fines, etc before applying primer. Use good enamel paints.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8454 |
Back in the 40's when they were new they were just painted bare metal, right?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87533 |
I buy a gallon of "RED OXIDE" primer (enamel) and brush it on when the parts are clean and dry. Then I set them on the shelf. This will keep them from rusting, and the bolted faces get some primer between them...... Weeks or months later when the parts are ready to assemble I final sandpaper the fenders / hood / tank to get any brush marks out. I reassemble the tractor without the fender / hood / tank and final spray paint the frame unit separate, then install the tank and hood. I use auto quality enamel paint. No need to sand the cast parts.
Edited by steve(ill) - 09 Feb 2016 at 4:56pm |
tractor with some "red oxide" primer brushed on a rebuild transmission - final drive- fenders - front and rear hubs.... front end rebuild at later date.
Using electrolysis, just be sure to get any residue off. I clean parts with lots of water after taking them out, dry off and lightly wire brush. I have left parts like that for some time without having rust form. Just before painting I spray or wipe things down with brake clean and blow dry. I am not a professional at painting but this has worked well for me.
Edited by CTuckerNWIL - 09 Feb 2016 at 5:42pm |
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
I was thinking that wiping the parts down with some sort of solvent to remove any oil was the one thing to add before any painting. If you forget that setup you can end up with some odd fingerprints in the final paint job. Repainted the grill of my 15 to hide some of them.
Play Farmer ![]() Orange Level ![]() Joined: 13 Jan 2016 Location: NNY Points: 732 |
I use self etching primer on my bare metal, and its been successful long term.
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2663 |
As Charlie said, wash thoroughly, dry it as fast as possible and I use a self etching primer. I have to dry and prime asap as everything will flash rust if I don't. I really like electrolysis, it's like having someone else working while you do other stuff.
I hang the parts up then using a spray bottle of mineral spirits I wash the parts down. As soon as they dry I hit them with primer then a second coat of primer and maybe a third coat of primer. Non-sheet metal parts get painted as soon as the primer dries. Sheet metal gets a final sanding followed by a bath of denatured alcohol and then several coats of paint.
1957 WD45 dad's first AC
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8472 |
My Steps after electrolysis would be something like this.
-Removed from bath. -Rinse with clean water. -Wire brush the black soot off as you rinse. -Blow dry with clean compressed air. -Wire brush again after dry and blow off. -Prime as soon as possible. -Set aside or top coat as desired. Even as slow as the process is I was still pressed to keep up with parts coming out of the E tank. One of the WD grills ![]() A WD fender ![]() Regards, Chris Edited by Sugarmaker - 10 Feb 2016 at 3:14pm |
Men, thanks for all the help and suggestions, I have started with these steps and it follows along with what you suggest.
1)Remove baked on grime, grease, caked on dust/oil, in Lye bath 2)Neutralize in Cleaning Vinegar 3)Rinse in cold water 4)Run through e tank (24-48) hours 5)Rinse with cold water 6)Brush-scrub-wire wheel-Dico wheel while still wet and rinse well 7)Dry thoroughly, towel, compressed air, and my secret, leaf blower 8)Sand, wire brush, scotch-brite a good dry cleaning 9)Blow off thoroughly and wipe down with acetone. 10)Prime with self etching primer or 11)Spray with a phosphoric acid based metal prep and rinse 12) Then you can spray with a good high build primer. Does this sound like a good process? My understanding on bare metal you need to use a self etching or red lead primer or the phosphoric wash. Thanks for all the great information! WOULD YOU TWEEK THIS IN ANY WAY? Ed |
Red Oxide is STILL the best primer as far as I am concerned!! FIL was a welder with almost 60 years experience and this is what he swore by and they used on EVERYTHING. Wish I had HALF his knowledge...he's dead now though... |
wdtom ![]() Silver Level ![]() Joined: 08 Dec 2015 Location: Foster, R.I. Points: 74 |
For clean metal and metal with the rust well removed or sandblasted I use Rustoleum white clean metal primer. One coat, then the Orange, Valspar tractor and implement paint I think it is, friend has the can now. I wipe down all surfaces with paint thinner before priming.
