Interchangeable torque tubes?
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Topic: Interchangeable torque tubes?
    Posted: 13 Nov 2015 at 8:59pm
Question:  Are torque tubes interchangeable between a B and a C?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 9:41pm
Parts books use the same part number for the B and the C Torque Tubes. Two of them actually. 210944 prior to 1951 and 224972 1951 and after.
   The answer is, Yes they will interchange
    The early B torque tube without provision for a electric starter is another story.
Edited by Ken in Texas - 13 Nov 2015 at 9:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 10:04pm
Thanks, Ken.  I have a 1938 B.  The previous owner broke the torque tube on the right front and welded it up.  It's working but has obvious welds.  There's an auction tomorrow 40 miles away.  They have 2 parts C's.  Both have electric start.  My B has no starter.  Will that make a difference?
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 10:19pm
I don't know for certain, but I will bet you will need the flywheel from the one with an electric starter so it will work.
Unless you want to keep hand cranking it every time.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 10:21pm
Thanks.  I'll see what the parts tractors bring tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 6:38am
A C torque tube will interchange with a early B torque tube if you want to convert your handcrank to electric start. The C starter flywheel and clutch & pressure plate can also be used to update. The 38 B foot rest will fit the C torque tube too.
If you lived closer I have all the parts to convert a Handcranker to electric start. Except. You will need to build a custom bracket to mount a genny on a Early BE engine.
Don't forget a different tool box and a battery and battery box. You may get all you need off one of those C parts tractors. Scrap prices today make a C for parts worth less than $100.
Edited by Ken in Texas - 14 Nov 2015 at 6:40am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 6:47am
Using a torque tube from a C to a B works fine. When using a B torque tube on a C, it will not have the holes tapped for the steering box support bracket. Just useless information added to this question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 7:55pm
Looked at the B's torque tube then went to the auction and looked at the C's torque tubes.  Found just what you said.  Want to keep the B original so didn't buy any parts tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 10:46pm
Good for you Dan. By updating a handcrank 38B to electric start it would no longer be a ALL 38B
It is tempting to modernize but if a historical accurate restoration is the goal, I congratulate you for your decision to keep your B as authentically accurate as possible.                  Ken in Texas
If you lived closer to Henderson Texas I would make you a gift of a authentic very nice 38B torque tube. And throw in a pair of wide 1938 B seat back supports if your 38 B needs them too.
Edited by Ken in Texas - 14 Nov 2015 at 10:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 9:24pm
Thanks, Ken.  If we or someone we know who can haul a torque tube get somewhere near your area I'll call you.  :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 1:24am
I have a few hand crank B torque tubes here. I can haul to Missouri AC swap in March. if interested call 612-508-4759 thanks Matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 8:45pm
Thanks, Matt.  I am planning to attend the swap meet.  I'll make a point of calling you before I head over to MO.
