Hugger head repair question.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Hugger head repair question.
    Posted: 13 Nov 2015 at 8:27pm
Getting to the point the stripper plates are getting pretty worn. Really could stand to change a seal in one of the row units.   Can the stripper plates be changed while its sitting on a header cart?   I would like work on it in my shop this winter but cann't fit the combine and head in my shop. The shed the combine sits in during the winter is not snow plowed to ( not my decision).
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 10:07pm
I would think the cross bar of the cart would be in the way. can you stand it up on its back ona sled/skids and pull it into your shop? that's how I work on my cornheads if I have to do anything major. sure is nice just standing/sitting there doing the work!
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 5:43am
You can. I have taken row units off on header car, removed spirals and flutes, and other repairs as well, on a cart
Edited by Amos - 14 Nov 2015 at 5:44am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 9:38pm
Shameless is right. Stand them up is the only way to work on them.  MACK
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 7:38am
Take a good look at the roll points too.  If they are worn, and you put new flutes on, the stalks won't feed into the rolls correctly since the new flutes will be tighter.  If the back of the spiral where it meets the flute doesn't come to a square corner, it will probably be best to put new points on.
