Calling series 4 owners
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: Calling series 4 owners
    Posted: 06 Sep 2015 at 11:31am
I have a 64 series four gas. And I don't think it's the original motor. The serial number on mine is 17-53685-M and I was wondering if you guys would mind getting me your engine serial ## no hurry but any help will be appreciated to find out the year on my motor. Or if someone has a web site that has the ser#s on it. Thanks.
Oh and here is the crank off of mine. I'd like to find the people who owned it before me.
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 3:02pm
Serial nos. are on this site.
http://www.allischalmers.com/serials.html
Ours is no D17 79103 3pt factory hitch.
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 4:08pm
My series IV's serial # is D-17-76815; engine serial # is -56097-
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 6:10pm
Was your crank pulley rattling and making noise? I think your crank is shot unless someone can fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 7:12pm
Pete, you couldn't tell it untill low idle, but it sounded more like a knock in the motor. And yep it's shot it is worse in person. sooo I will be looking for a new crank..
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 7:15pm
I think IV has harden journal on crank.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 8:11pm
  We had a WC crank with the same problem fixed by a machine shop in Shelbyville, IL .  If the crank is good otherwise it might be worth checking into getting it fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 8:30pm
That nose on the crank can be fixed with a good epoxy. I fixed a flywheel on the back shaft of a 2,500 ton forged press with a Moglice product for static fit. Just takes lining up the pulley and filling the void.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 8:05pm
I have D17IV, serial number 82077, with engine number 17-85405-M.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2015 at 9:32pm
Josh - happened to mine back in like 1996/1997 and I ended up having to get a different crank too, couldn't be fixed.  Good luck.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
This page was generated in 0.139 seconds.
