Ford Industrial engine |
Rod in MN
Topic: Ford Industrial enginePosted: 26 Feb 2015 at 8:08am |
Hi Guy's I'm looking for engine parts for a ford Industrial engine. What is the difference between the industrial engine and one in a Ford car it is a 1.1 liter engine in a OMC Mustang 345 Skid Street ??
Thanks Rod |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54709 |
Posted: 26 Feb 2015 at 8:17am |
Most industrial ford motors were gas 134 CI, 172CI, or 196?CI. A few applications also used a pinto motor. Look on the valve cover, should have an ID plate, midway down the side of it, IIRR.
Posted: 26 Feb 2015 at 8:18am |
Usually, Industrial engines have forged pistons, stellite exhaust valves and a steel crankshaft, etc, etc. They aren't the same, even tho they might look the same to you. In the case of a GM 350 V-8 they even had 4 bolt main bearing caps on the Industrial version.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 26 Feb 2015 at 8:43am |
Not sure what is Difference ,They do have 5 Or 3 main bearings .Not all 1.1 have same bores . One of the engine suppliers that I am a dealer for has the parts for them .
Send me a PM with what you need and I can give you price . Edited by Fred in Pa - 26 Feb 2015 at 6:29pm |
Joined: 11 Sep 2009 Location: illinois Points: 89196 |
Posted: 26 Feb 2015 at 8:54am |
I would bet the cam shaft / valve overlap and timing are different for a constant speed motor (2000 RPM) compared to a car.
Edited by steve(ill) - 26 Feb 2015 at 8:54am |
Allen Dilg
Posted: 26 Feb 2015 at 1:19pm |
Hello Rod Need to know the model? Have 2 small Ford motors on high crop sprayers.
Rod in MN
Posted: 26 Feb 2015 at 1:44pm |
Allen This is what I got from father in law of the valve cover
HD,P Block,1C Date-Serial# E1268-100 Build# Z-320-TK5-200 1.1L Ford Industrial engine. What is the difference with ford engines and ford Industrial engine. Parts for the Industrial engines is higher $ and harder to find. NAPA can not find them or get them. Auto engines can find all over ?? Thanks Rod |
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11802 |
Posted: 26 Feb 2015 at 4:57pm |
I think the 1.1 is a British made engine. Not the same as a Pinto engine that was 2.3L
