Front Wheel Bearings
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Front Wheel Bearings
    Posted: 08 Oct 2012 at 12:02am
I had the idea to clean, re-pack the grease on the front wheel bearings on the C.
The rollers fell out (bigger, inner bearing). Isn't that roller cage supposed to retain them? It was a pain to get them back in and stick as I put the hub back on. The cage looks a little tweaked and worn. Maybe time to replace the bearing set? Most likely they are the originals.
How easy is it to change them if required.
Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 7:58am
Time for new bearings. They are worn out.  MACK
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 8:03am
I've been there done that but I found the bearings to be quite servicable once reassembled. I think the cage gets "tweaked" by running the bearing too slack.
Edited by SteveC(NS) - 08 Oct 2012 at 8:04am
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 10:19am
As Mack said, time for new bearings.  If the "rollers" have fallen out of the "cage", it's shot.  None of that is supposed to come apart.  New bearings  (and new race/cone) are the solution.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 2:26pm
Pretty easy to change as well.
jeffsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 3:10pm
ought to be pretty simple for you to change them,you have already done most of the job
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 3:29pm
I agree.  They can be put back usually, but I choose to just replace and I won't be doing that again for a long time.
