HD5/HD6/HD-344 Power Unit Radiator Interchage |
orangeman
Orange Level Joined: 12 Sep 2009 Points: 1696 |
Posted: 30 Sep 2012 at 9:48am |
Guys: Work is progressing to bring the venerable HD6 G Shovel back to life. One defect I noticed was the radiator on my HD6G is in dire need of replacement.
Am looking through parts books and see the following listed for the Radiator Assembly: HD5 G - Part Number 050516 HD6 G - Part Number 092023 also a hand written parts number appears to supercede that shows 70649436 (includes armored tubes at rear of core). D-344 Industrial Engines and Power Units - Part Number 4348919 Do any of you guys know if there is any interchangeability between the above? If not I will need to tap your knowledge to obtain a good vendor(s) that can provided a good core for my original radiator. I welcome and appreciate any and all comments. Thank-you...Orangeman
dadsdozerhd5b
Orange Level Joined: 27 Sep 2009 Location: lansdale pa. Points: 527 |
i would think the hd6 rad would be bigger as it has a bigger engine and more heat. i think they were the same housing but not sure. sit down when you get the price of a core. last i heard they were in the 1200 dollar range but i thought that was high. i have no good source, sorry. good luck
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41251 |
HD5 is open system and not a pressure unit , unsure of the others . You might check some sizes and see what else might fit as far as truck unit. I believe the HD6 was wider in front mount and radiator was larger than the 5 could accommodate.
Jay Tyrrell
Silver Level Joined: 28 Jul 2011 Location: Staples Points: 65 |
I'm no rocket sciencetist but my HD6G didn't have radiator in it when i got it. Took a radiator from a forklift at work (JLG G9-43A) and made it fit. Had to move lower port on the radiator, that was pretty much it. Could have moved the radiator fill cap to center but the Gas/Ax was cheaper, and I cut a hole in the hood off to the side for access. Radiator was off a 100HP engine so it has plenty a capacity. Works great.My Point:Any heavy duty radiator will work as long as the fisical size fits. Moving ports and making suport bracets is alot cheaper then $1,200 core
Edited by Jay Tyrrell - 02 Oct 2012 at 6:48am |
ac_sd
Silver Level Joined: 23 Apr 2011 Points: 194 |
HD-5 and HD-6 radiators are completely different... Not sure about the 344 Power unit radiator.
orangeman
Anyone on here seen or heard of a Buda or AC HD-344 in application. The must have been put in something but what I am not sure. Maybe barges or tugs?
I have only seen one picture of a HD-344 and it was coupled to a generator. I know the military used the 7000 engine but that engine is a bit different than the early HD-344 block. Any thoughts or comments on applications would be of great help! Thank-you..Orangeman
Ages Cat
Orange Level Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 681 |
The 344 was used in the HD-6, prior to serial number 13322. After that it became the 6000 with pencil type injectors which started better and ran much cleaner. The T-16 four wheel drive tractor also used the 344, along with the 145 and M70 motor grader and the TL-14 and TL-16 wheel loaders. i have 2 HD-6's one with a 6000 and one with a 344 converted to a 6000. They are good little engines that start great and don't use a lot of fuel.
