Allis Suitcase Weights
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Suitcase Weights
    Posted: 16 Sep 2012 at 7:45pm
I have been looking for some suitcase weights for my one-sixty.  From some previous information I understood that I needed those with casting number 255444 (same as what the one-seventy would have).  I have located some with casting number 255861.  Based upon Brian Ahart's web site, the 255861 would be for the 200/210/220 tractors.  However, I am told these 255861 came off a 185.  Does anyone know whether the 255861 weights would work on the one-sixty?  It has the factory weight bracket.  Thanks, Dave
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2012 at 8:00pm
I dont know if they will work but i sent you a pm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2012 at 8:04pm
Orange knight had some 160 weights for sale awhile back on the classified adds a while back
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2012 at 8:08pm
weights for a 160 are like a 185 weight
                  IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2012 at 8:28pm
The weights orange knight had, were a different casting number and didn't quite look like what I needed.  Also, he only had five of them, and I need six.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 8:01am
someone is parting out a 160 currently, on E-Slay.
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 1:51pm
i thought the 160 only took 5 front weights? Ill check ours when i go out to the farm tonight
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 1:55pm
for the ones you have you have to have u need a weight bracket that has the square cut outs for them to work properly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 2:03pm
Jason, could you also check the casting number so I know that the 255444 is the correct ones.  I'm pretty sure about needing six, but a confirmation on that would be appreciated, too.  Thanks, Dave
Elvin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elvin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 4:00pm
Dave, I have 10 0f the 255444 weights. I will sell these or trade you for the 255861 weights that you said you had found elsewhere, Call 785/224-4560.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 9:27pm
6 weights and end in 444. Those weights you have off that 185 are kind of hard to find and make a 220/210/200 look really good. i have a set of them on my 190 xt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 7:50pm
Hey, Jason, is there any sort of bar or rod that is used to hold the weights down in place?  Just wondering if there was something like that on your one-sixty.  Have seen similar on other suitcase weights.  Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 8:51pm
It uses a small inch bar that takes up the space between the weights and the weight bracket. Runs through the 6 weights and one side has a press pin on one side of it and on the other side is a snap pin so you can take that side off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 9:04pm
Dave those weights you have are worth more then any other AC suitcase weight out there.
                                                           IG
