WD motor
jacnmars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacnmars Quote  Post ReplyReply Direct Link To This Post Topic: WD motor
    Posted: 31 Aug 2012 at 6:07pm
What other tractors will the motor from my WD bolt into?
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 6:36pm
B, C, CA, WD, and WD45. Pretty sure it will go in a d17 as well.
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:04pm
It will bolt into a WC, WD, WD45. Also WF and D17 assuming on the 17 that the bellhousing adapter is there. Otherwise, unless there is something I am horribly unaware of, It will NOT bolt into a b c or CA. I suppose you also need to mention the RC too, it will bolt into it.(although that would turn it back into a WC essentially)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:16pm
If a CE engine bolts to an RC and a WD engine will bolt to it, why can't a WD engine bolt to a CA? Never been around an RC so there must be something different.
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:23pm
Same deal I believe, there is a bell housing adapter for the RC to accomodate the C engine  but as far as I know there is no way to go the opposite, that is a WD engine to a B C family rear end
Edited by oldorangeiron - 31 Aug 2012 at 7:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:28pm
I want one then, the adapter I mean. Then turn it around backwards and bolt a WD engine in a CASmile
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:36pm
Wish I had an RC and I'd see if it was even possible LOL
Might be neat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:46pm
If you build it................ I have seen a GM V8 diesel bolted in place of a 2 cylinder JD engine. Anything's possible.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 7:49pm
When the 125 engine was used in the RC they didn't use the two top holes in the bell-housing. It is not possible to put the WC - WD engine into a B or C unless you have a large machine shop, there was one at the orange spectacular a few years ago that was major progect like one off flywheel and cutom sheet metal.
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 8:00pm
I figured there was a hitch to it, or else we would see it from time to time. Neat thought though I guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacnmars Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 6:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacnmars Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 6:31am
thanks for the info  will this engine bolt into all d series
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 7:05am
No It will only work in the d17
This page was generated in 0.045 seconds.
