dye hydraulic fluid |
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Jul 2012 at 11:07am |
Always had a hard time reading the dip stick because the fluid is clear. Would if be safe to add a toutch of food coloring to my fluid to make it easier to read?
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
I have heard that they make special dye for oils. When we switched oil suppliers, the new supplier's 821 compatible oil is very light colored and nearly impossible to see in the sight glasses of the 7000 series tractors. The salesman (from Universal Lubricants) promised to get me some dye, but I aint seen any yet (and that was 3 years ago!)
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4734 |
The red dye put in diesel fuel to make off road fuel should work if you could get some.
Ray |
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
in missouri MFA OIL CO. has purple hyd oil it looks like grape juice.
H Clark ![]() Silver Level ![]() Joined: 11 Jul 2010 Location: West Virginia Points: 404 |
Yes they do make dyes for oil. I have used some from caterpillar. The Cat part number is 9u 5032 that is blue. I know that they make other colors also that is just what I have on my service truck. It is very concentrated an little bit will dye alot of oil.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6069 |
Many fuel dyes are incredibly carcinogenic and dangerous to handle.
One way you can get the dye result, is to dump in a bottle of common ATF- it already has dye, and won't adversely affect the hydraulic fluid. |
