gleaner power fold ladder???? |
clint ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: kentucky Points: 314 |
![]() ![]() ![]() ![]() ![]() Posted: 25 May 2012 at 9:00am |
i just bought an 84 L3 and would like to build or put on a power fold ladder.
thoughts would be- add the factory setup used if anybody has one.
or
use a couple tiny cyl i have from other sprayers and engineer this to plum into the reel height port for use in corn
does anybody have a used system sitting on a scrap machine?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Dale-OH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: SW OHIO Points: 909 |
The newer gleaners used a electric actuator for a ladder raise, two electric wires are a lot easier to run then hydraulic hoses. I think new actuators are around $400-450
dale- mind if i give you a call?
No Problem. 800-996-2937 office or 740-505-0227 Cell
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 771 |
I think the factory power fold was one electic actuator. The switch was down by the header height control.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
wi50 ![]() Orange Level ![]() Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
We had a Gleaner R62, and it did not have the ladder lift. I wanted to put one on but never did. The ones I seen used an electric actuator.
I just bought a new seed tender cart and it uses an electric actuator, but it's an electric pump and a small hyd cylinder all self contained unit to raise the auger. I can look at it and get you the brand and model, etc if it's something that intrests you, just send a PM.
I'm sure they are both pretty spendy items. I wonder how a cheap small light duity electric winch would work from an ATV or something with a little fabrication.
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Surplus Center in Lincoln, Ne has actuators, maybe something that would work.
Allis Express participant |
I bought a small 12V wench, mounted on grain bin. Won't win a beauty contest, but does the job. MACK
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
My neighbor threw a new one for a dish antenna in the back of my van, I haven't even looked at it, don't know what the voltage is for it. I guess I will have to open the box and have a look at it.
Dusty
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
I am with Mack. Those cheapo $50 winches can do a lot. One of our L2s had the manual/cable engage for the unloading auger. The cable broke, I tried to repair it, broke it again. AGCO wanted $96 for the cable. I put a $50 HF winch in its place, and swapped the belt to the other side of the idler, now I goose the button, auger starts, push the other button, it shuts off. Aint exactly factory pretty, but it works.
jjpetrich ![]() Silver Level ![]() ![]() Joined: 06 Sep 2011 Location: Marshall, MN Points: 137 |
It would be best to go electric then with the ladder down to make sure that a spacer is under the cylinder so that if someone steps on it it doest break, been seeing that alot on the s77's.
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21721 |
Why don't you just modify the ladder so it doesn't need to be folded up all the time?? You'll soon find out there are times you simply need to get in and out of the cab quickly and often, and there you go....wait for the d#$% ladder to go down and back up.....and then, when the electric motor fails, you spend more $$$$ to keep it working.
CORLEWFARM ![]() Bronze Level Access ![]() Joined: 25 Jan 2011 Points: 115 |
i guess you have a 4 row head,so just open up the field with the ladder up then leave it down the rest of the time
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
I only fold it up when I store the combine because of space issues and because I left the ladder down on my L2 once and hooked it with another piece of equipment
Wink I am a Russian Bot |
You're taxing my memory, but I think all we did was remove the rubber stops to allow the ladder to swing in closer to the tire. I think we had to trim off some steel in the stop area too. Yes, it makes the climbing angle a little harder, but the ladder sticks waaaaaay out farther than it really needs to be knocking down the next row of corn.
Edited by DrAllis - 18 Jul 2019 at 8:13am |
farmboy520 ![]() Orange Level Access ![]() ![]() Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Dad took and cut the ladder on an F we had and welded it back with less of an angle. It made it close to the tire but didn't have to raise it all the time.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
I just want my ladder to fold out of the way so I don't ever hook it again like I did on my L2. The L2 ladder must be half the weight of the R52. I can barely lift it on the R52.
I will take a picture tonight of my R62 ladder. It has the power fold
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
This might be EXACTLY why the previous owner of our F2 tapped into the "reel" lift circuit for his/now our ladder lift ???
Clint, just to verify, just what corn head are you running on your "new to you" machine?
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8454 |
My 860 cotton stripper (K2 chassis) has a rope on the ladder and a latch up top. Just pull it up, or let it down manually. No motors to fail.
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
IMO call around to a salvage yard and get the OEM setup. affordable, warm fuzzy feeling of OEM components. :)
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
AC 426 power ![]() Orange Level Access ![]() ![]() Joined: 01 May 2012 Location: Ohio Points: 525 |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5590 |
The N6 had two switches. One in the cab and a second one under the tin work on the left side.
Edited by Lonn - 20 Aug 2019 at 6:52am |
My R62 has 2 switches also. There is 1 in the cab and another by the base of the unloading auger.
