D14 Help
BIG MIKE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Topic: D14 Help
    Posted: 18 May 2012 at 4:05pm
I have a D14 that has about 150 hours on a complete overhaul.Tractor ran great till lately but now the warmer it gets the more choke I have to use to keep it running good.After it warms up it will only run with choke on then after awhile i have to go to full choke.I have checked everthing i can think of tryed it with 2 new carburators same thing.I was thinking maybe a crack it manifold that the crack gets opens more the warmer it gets.Open to any ideals anyone has on this matter.Thanks Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 5:20pm
I would warm it up and spray some carb cleaner around the manifold. If the engine speed changes, you have a leak that needs fixed. It is possible to have an internal crack between the exhaust and intake that opens up with heat. Have you checked for good fuel supply from the tank all the way to the carb bowl? Any obstruction in the fuel system could cause the symptoms but usually not as it heats up??????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 7:01pm
Thanks will try spraying the cleaner should it bog down alot or a little.Got good fuel supply.Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 9:53pm
Check the air cleaner.  It could be plugged up.
Soilguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Soilguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 8:13am
Mike; if it has an intake manifold leak, the engine will rev up a bit as it aspirates the combustable spray through a crack. Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:21am
If the air cleaner was plugged, he wouldn't have to choke it to keep it running,  it would already be choked??????????????????
