Rim widening advice ?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: Rim widening advice ?
    Posted: 29 Jan 2012 at 7:35am
I thought that I asked this before but couldn't find the post. I'm putting 30.5 tires on my 210 so have to widen the rim which we do in our own shop. I'm leaning towards adding the width to the outside of the mounting ridge. I also plan to install an outside 1100 lbs Tyler wheel weight and would prefer if the weight did not stick out past the tire. Any thoughts, pictures, or advice?
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 11:19am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 11:25am
That be a good picture of how it is done.
My Dad had that done to the wheels on his Oliver 77 in the 1950's when he was pulling. Not quite that wide.Smile He added two inches the same way on 38 inch rims.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 11:35am
  the secret to widening rims is the cutting of them   have widened many
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 11:36am
This is what we did for our combine.We added 10 inches,from 18.4x26 to 28x26.The only thing I would say is tack everything in place, mount rim on tractor and spin it to see if it straight.You can keep stitch welding it in various places, but keep checkingit till your confident it's OK. Put a block of wood on the floor near the lip of the rim, and watch how much the gap changes as you are turning.Hard to get perfect but you wont be superstocking it, will you.LOL. When you cut the rim apart, try not to go too close to the lip;the more material you have on the small piece the straighter it will remain.We cut it with a plasma, lot colder cut than a torch. I am no expert, I watched/helped my brother, he is.HTH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 12:13pm
Norm is right that the cutting is the secret. Have done many here before as well. Looking for advice on where to add the 6" and other people's experience on the same size rim.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 9:08pm
Easy way to cut rims streight. Take 2 roller skates weld a light frame between the two the width of inner rim. Mount plasma cutter on frame where you want to cut. Roll acrose the shop and cut. Works good.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 11:30pm
I bought combine rims and cut the center out then welded a chunk on the drop ctr. The rims with the cracked centers are cheaper. The thing I don't like is the cast center is out farther on the axle. Maybe on shop built ones you can put the off set in a better location to keep the "wheel" next to the axle hsg.
