Tractor generator
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: Tractor generator
    Posted: 16 Jan 2012 at 12:09pm
Did all the older allises from the 40's and 50's have the same generator, or did they switch with the model? Thanks!
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 1:21pm
They used both delco and autolite.  Also the B,C,CA used the short frame gen and the larger tractors WC,WD,45 used the standard frame unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 1:40pm
Can you put a wc's generator on a b's generator mount?
Edited by bigcountry48 - 16 Jan 2012 at 1:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 6:01pm
Most all the 6V chassis profiles were the same. The 12V chassis' were a tick longer. Some of the units had a step in the body of them toward the rear of the unit. HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 8:59pm
So if I were to take the generator off of a 1947 WC, it would fit in to the bracket from my 1950 B's old generator.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 9:39pm
YES, Measure it
This page was generated in 0.044 seconds.
