8000 Fwd design |
Eric[IL]
Topic: 8000 Fwd designPosted: 16 Dec 2011 at 9:35am |
I am reading Norm Swinford's AC book about the Fwd tractors. The 5000, 6000, & 8000 series fwd notes and have a few questions.
Q1. If I understand correctly, AC did not manufacture the 8000 fwd axles & drivelines? If not AC, then what brand did build these items - was it Fiat? Q2. When AC realized that the 7060 rear axle final drives used in the 8050 were acceptable for the 8070 fwd & 2wd tractors, then what differences are there between the 8050 & 8070 tractors?
Russ-neia
Posted: 16 Dec 2011 at 10:16am |
Company called SIGE made the 8000 front axle. It was made in Italy, but I don't know if it was connected to Fiat.
The innovators offer what others will imitate.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 16 Dec 2011 at 2:39pm |
John Deere doesn't even make their front drive axles, as told by a former dealer. Fiat supplied front drive axles for the 5000 and 6000 series.
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 16 Dec 2011 at 3:15pm |
It was a privately held company. They were very good people to work with. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Mike_426
Joined: 07 Dec 2011 Location: Ypsilanti Mi Points: 138 |
Posted: 16 Dec 2011 at 9:02pm |
The 8070 and 8050 are close to the same machine. 8070 has a different injector pump and a balanced crankshaft, also had 3 hyd. valves in back where as most 8050's came with two ...
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
Russ-neia
Posted: 16 Dec 2011 at 9:13pm |
Mark, do you know what became of SIGE? What other companies did they supply axles for? What other products did they manufacture? It is becoming difficult and/or expensive to get some of the SIGE axle parts from AGCO.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8734 |
Posted: 16 Dec 2011 at 9:20pm |
Beefier PD in 8070.Bigger radiator too I think.Books in the shop...I'm in the house. Bigger axles maybe? Mine are 4"
Dual hyd std.Triple...option.Mine has only 2 Edited by SteveM C/IL - 16 Dec 2011 at 9:22pm |
Mike_426
Posted: 16 Dec 2011 at 9:23pm |
My 8050 also has four inch along with the 4 pinion rearend. Powershift in mine, forgot about that pd in 8070's |
MACK
Posted: 16 Dec 2011 at 9:28pm |
I think Sige is or was a part of Deutz.
As far as price of parts, any FWA no matter the color is out rages. MACK
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Posted: 16 Dec 2011 at 9:46pm |
When we owned an 8030 FWD I changed the crosses to greaseable type.Had to grind a little out of the joint so that the grease fitting did not hit when rotated.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Dave in il
Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
Posted: 16 Dec 2011 at 10:10pm |
I thought the 7080 and 8070 shared final drives and rear ends, the final drives and axles were bigger on my 7080 but I guess I never paid attention to the 8070
Posted: 16 Dec 2011 at 11:17pm |
They used the same finals til ser#2662 on 2wd,then the 8070 used the same finals(width/ratio) as 8050. FWA used same as 8050 throughout.
TREVMAN
Joined: 04 Jan 2010 Location: Regina,Sask,Can Points: 1635 |
Posted: 18 Dec 2011 at 6:26pm |
Ford used sige axles, Trev.
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1167 |
Posted: 19 Dec 2011 at 4:18pm |
Whats the name of the book? I thought Norm Swinford only had 2 or 3 AC books out |
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
