190 Slow Hydraulic Problem
dave b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave b Quote  Post ReplyReply Direct Link To This Post Topic: 190 Slow Hydraulic Problem
    Posted: 22 Nov 2011 at 10:35pm
When cold, my 190's hydraulics seem slow. My power-steering is choppy, my lift-ram is slow, and my power director doesn't work. When warmed up, everything seems great. In the manual, it says remove, clean, and replace suction filter located behind left-hand engine side frame. Where is this located? I assume it's not the spin-on filter.
Thanks
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:39pm
It's between the left frame rail and the left side of the engine, large tube in the return line. The filter is inside the large section of the line.
Edited by DaveCinIN - 22 Nov 2011 at 11:39pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:09am
Yours may not have the filter. Later tractors did not use them because the rubber caps on the ends would suck air so they done away with them.
 Check all the connections on that suction tube. Could also be front seal in pump. They will get hard from heat and not seal causing punp to suck air.  MACK
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 1:46pm
not sure where you are but if you have water in the fluid that could give you problems in the cold, does the fluid look brownish?
been there done that, not doing it again...
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 7:33pm
There is a strainer in the sump.
