Print Page | Close Window
190 Slow Hydraulic Problem
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=40981
Printed Date: 29 Aug 2025 at 6:59am
Topic: 190 Slow Hydraulic Problem
Posted By: dave b
Subject: 190 Slow Hydraulic Problem
Date Posted: 22 Nov 2011 at 10:35pm
When cold, my 190's hydraulics seem slow. My power-steering is choppy, my lift-ram is slow, and my power director doesn't work. When warmed up, everything seems great. In the manual, it says remove, clean, and replace suction filter located behind left-hand engine side frame. Where is this located? I assume it's not the spin-on filter.
Thanks
Posted By: DaveCinIN
Date Posted: 22 Nov 2011 at 11:39pm
It's between the left frame rail and the left side of the engine, large tube in the return line. The filter is inside the large section of the line.
Posted By: MACK
Date Posted: 23 Nov 2011 at 8:09am
Yours may not have the filter. Later tractors did not use them because the rubber caps on the ends would suck air so they done away with them.
 Check all the connections on that suction tube. Could also be front seal in pump. They will get hard from heat and not seal causing punp to suck air.  MACK
Posted By: Flint23
Date Posted: 23 Nov 2011 at 1:46pm
not sure where you are but if you have water in the fluid that could give you problems in the cold, does the fluid look brownish?
been there done that, not doing it again...
Posted By: Joe(TX)
Date Posted: 23 Nov 2011 at 7:33pm
There is a strainer in the sump.
