wd intermediate gear broken.
brittfan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittfan Quote  Post ReplyReply Direct Link To This Post Topic: wd intermediate gear broken.
    Posted: 29 Aug 2011 at 9:02pm
Howdy all. I tried doing a search on this but got my head spinning. I have a '49 WD, and need to replace the intermediate gear.  I've already pulled the PTO box off, and the intermediate gears not looking so good. Any tips out  there??
Thanks in advance,
Bill
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2011 at 10:06pm
Not sure what freight would be but if you cant get it I have the whole assembly from the bellhousing to the front of the trans with the wet clutch still in it laying on the floor of the shop if you needed it.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2011 at 10:26pm
Are you asking how to replace it?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittfan Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 9:12am
Yes, how to replace it. I thought I read that it can be done without splitting the tractor.
Thanks.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 9:48am
In theory, yes.  I have about a 50% success rate at getting them out without a split.
Drain PTO, Drop PTO, now you can see the broken gear.  There is a set screw towards the rear of the tractor inside the cavity.  Remove it.
Pull Hydraulic pump.  Now here's where it gets "iffy".  Slide the shaft holding the PTO intermediate gear into the cavity where the pump was.  I have a hard time getting a hold of the shaft.  Sometimes it just slides right over, and others, it's stuck.
We have the gear in stock when you get ready.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittfan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 7:49am
Thanks, I'll give it a try.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 8:16pm
when you put it back together dont use a rear thick gasket on the pto box it will greatly reduce your tooth contact and bust another tooth off. never go with anything over .015 gasket on the box.need to ck your gear backlash when installed...
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittfan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 6:05pm
How much backlash should I be looking for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2011 at 8:30pm
according to the wd-45 ohm the only measurement is between idler gear and the intermediate gear.if less than .004 backlash,use 2 gaskets
This page was generated in 0.077 seconds.
