D-19
JoeRepking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeRepking Quote  Post ReplyReply Direct Link To This Post Topic: D-19
    Posted: 31 Aug 2011 at 9:38pm
Has anyone put a 301 diesel in a d-19?? was wanting to do it to mine and wondering if it would work.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:40pm
The local dealer has one. Its a fairly easy swap according to him. Id like to do it to ours someday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeRepking Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:43pm
My gasser is shot and i am contemplating the conversion!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeRepking Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2011 at 9:45pm
what does it all take ?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 7:37am
I want to know too cause that's my plan. Either that or drag Dad's gasser 190 out of the weeds and put the diesel in her but that one needs a new hydraulic pump and the one bull gear got chewed up years ago from losing a bearing soon after hitting a deep hole in the field when I was moving round bales in 7th gear flying. Never go that fast in the field again. The heater/AC knobs in the 7000 series cab left an impression or was it a depression in my forehead.
Wink
I am a Russian Bot
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:43am
I,am probly giong to do it also from what I have gathered I need to gain 4 inches in frame maybe because it has the four belt crank pully. What I've heard is there is a little grinding involved for the starter and flywheel. The thing Ineed to worry about is power steering mine is out of a combine and has no pump on the motor so I have to get some hyd. pressure somewere. Other than that it bolt right to the bellhousing I'am not 100% sure on the flywheel clutch combo to use but I have both so I guess I find out when the time comes. Be nice to surprise some people at the pulls.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:57am
Il have to ask him again for more details next time I talk to him. I do remember him saying he used 190 frame rails (there a little bit wider). Hecut the 19 frame rails off at the radiator,because the 190 are about 1/2" wider so he bolted them to the outside of what was left of the 19s. He also used the hydraulic pump on the motor so it has live hydraulics.
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 2:33pm
would be great to see a pic if possible
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 1:12pm
Unless you just want a 301, the 200 (2/3 of 301) has plenty of power for a D19 and frame will not need stretched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeRepking Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 7:26pm
why would it not need to be stretched??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 7:32pm
The 301 is a little longer than the original 262, or so I've heard. The 200 engine is a 4cyl and is shorter than the 262.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2011 at 8:55pm
Il have to check, but I dont think length was the deal with using the 190 frame rails, It was the width. The 190s are about an inch wider.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 6:51pm
 Joe how about a 433 out of an F3. Same as the 6080. Its 4 cylinder turbo. Sitting in my shop you can hear it run.
                                                IG
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 7:54pm
I've always thought that a 433 T would be real neat in a D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2011 at 9:42pm
The 433 would still run into the same problems as far as width.
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2011 at 8:57pm
This page was generated in 0.071 seconds.
