Height Control - Bush Hog
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Height Control - Bush Hog
    Posted: 16 Aug 2011 at 12:13pm
I have always had a problem controling the height on my 3PH Bush Hog with the hydraulics; the lift arms always seem to "leak down" and I have to continually reset them
I  devised an adjustable "stop" bar for the lift arms on my D-17 when I had the Bush Hog on it last year.
This year, I'm using my WD and I had to devise an adjustable stop for it as well.
The stop works well but I am curious as to what you other guys do.
Or.......am I the only one who has the problem?  LOL
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 12:22pm
Owned three D-17's S1, S3, S4 and all the lift arms creep down.  Some more than others.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 1:47pm
Many guys leave the top link out and attach a chain to where the top link would go on the tractor and pin the chain to where the lift arms pin to the bush hog.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 3:24pm
This is how I handled the problem.
I used scrap parts I had lying around including some "green" stuff.
Oh, its Deutz-Allis, at least.
Tried to keep it in the family.  LO
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 8:45pm
If you have exposed cylinders as on a WD or WD 45 you can use a series of cylinder depth stops which are merely spring collars that snap around the cylinder rams and can give your  bush hog the height you need.  Use them on a Woods 3 pt on a WD 45.  Obviously only works if you have exposed cylinders.  I bought the tractor and mower as a unit and it already had them on it.
Dennis J
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2011 at 11:26pm
Buy a 170 or 175.....heighth control works great on these tractors!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 8:11am
Now Eldon, that would be nice! I've graduated from a WD to 2 WD-45s to a SII D-17.
I guess the next step should be a 170 or 175.
Now......I just need to find one cheap enuf for me to afford.  LOL
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:08am
Replaced the seat in the hold position valve a couple of years ago and now it will hold a plow up indefinately. I have a D17 S1 with the transport valve and it will leak down in a hour. I always assumed it was the transport valve but maybe not.
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 12:38am
2 pieces of 1/4 or 5/16 chain about 30-36 inches long. 2 hooks.  4 pieces of 1/4 or 5/16 thick steel, 2 inches wide and 6-8 inches long.  Drill the end of 2 pieces of steel to fit on the lower lift pins, weld the end of a chain to the other end of each.  Drill the other 2 pieces of steel to fit the top link at the tractor, weld a hook to the other end of each of these.  With a long pin you can leave the third link on and use these chains to control and adjust the height.  Have used this on the D15 and the B, might have to do something else on the WD due to the platform..  Just make sure you tie up the loose ends of the chain after you get it set.  Gets way too close to the PTO if you don't.
This page was generated in 0.083 seconds.
