Factory WD-45 Hi-Crop Question
KevinC(MD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinC(MD) Quote  Post ReplyReply Direct Link To This Post Topic: Factory WD-45 Hi-Crop Question
    Posted: 10 Aug 2011 at 6:18am
I have to appeal this question to the folks who will definitely know...Could a farmer who wanted a hi-crop Allis WD or WD-45 in the 1950's order a model from his local Allis dealer or would he be forced to build one himself?  Is the Hi-Crop a FACTORY offering, not just a tire/rim/center option in the parts book?  I'm familiar with the conversion company's offerings, but as you can guess, this is a pulling club question.  Thanks much.  Kevin
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 8:47am
  I have the same question.  Recently, I acquired a WD with 38 inch rear tires and with other differences like no PTO unit and extensions in the front axel spindles.  Were there any other differences and did these come from the factory?  Thanks.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 11:15am
I would have to say yes it was factory offered. You do see the "special" parts offered with the High crop in the factory parts manual. the taller front spindles for the wide front, and the taller front "yoke" for the single front, How ever I did not see anything with the dual wheel narrow front for the high crop.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 11:32am
Is the question about 38 inch rubber?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 12:07pm
Heres a question....
With all the High Crops, were they able to use any snap coupler equipment at all?
Or were they used strictly for pulling or other implements that were built for them?
thanks
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinC(MD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 12:26pm
Yes, was it available on a tractor directly from the factory?  Thanks.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 5:47pm
I really can't help on most of the questions, but this is DaveinGB's 45 highcrop which I'm pretty sure has 38's on it...hopefully He'll see this post and chime in with some details.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 6:48pm
I do not have Pop's price book with me but from my memory, the high crops were ordered from the factory with high crop wheels, spindles, and whatever else was needed.  It was also noted in the book that these units with the high crop attachments were not for heavy tillage use.  It seemed the high crops were for cultivation and such only.
Good Luck!
Bill Long
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 8:16pm
  if it listed in parts book it is all probably  factory like the 38,s
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 9:13pm
38" rears are listed in the WD-45 parts book. Found this for a friend a few years ago who needed to know for the same reason.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2011 at 9:22pm
Thanks for posting  a picture of my 55 sfw Hi-Crop Chad.  Near as I can tell, this tractor was used to pull a sprayer in the vegetable fields in calif.  It had allis 38" power shift wheels  from a D-series.  It was missing the hydraulics and in place of the snap coupler hitch, it had a HD homemade hitch.  The single front  wheel with the tall fork is original to the tractor.  I put the 8 to 9bolt rear wheel adapters and wheels and rims on it as shown in the parts book.  It rolls down the road at a pretty good clip!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinC(MD) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 3:42am
Much thanks to everyone.  The information certainly helps.  Have a great day from MD!
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 12:24pm
was it possible to use the farcory wheel weights for these rims or did they have something special?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 8:26pm
I dont think the wheel weights would work.  Like Bill Long said, those things were no draft animals.  Specialty work only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2011 at 9:21pm
I can still see where weight would come in handy, (clay, dried mud etc)
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 10:02pm
I measured the holes on my 38 inch wheels.  It does not look like the WD, WD45, etc weights would work on these wheels due to differences in spacing.
